Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 04-09-2010, 01:53 PM
rzimmerl's Avatar
rzimmerl rzimmerl is offline
scAR'd
SCCoA Member #: 2515
Send a message via AIM to rzimmerl
Stock location billet fuel filter
Been thinking about replacing the stock fuel filter with a billet reusable filter. The stock filter is 3" OAL at the filter area. These are for -6 size filter I/O.
This filter should fit, 3" OAL x 1.25" Dia., 40 micron filter, what micron is needed?
http://www.summitracing.com/parts/RUS-650133/
Then use these fittings to adapt to the stock line, not sure what size it is yet
5/16 - http://www.summitracing.com/parts/RUS-640930/
3/8 - http://www.summitracing.com/parts/RUS-640940/
Then join them with these couplers
http://www.summitracing.com/parts/SUM-220641B/
Just an idea instead of replacing the stock filter, let me know if I'm off the wall on this one.
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
Old 04-09-2010, 01:58 PM
bowez bowez is offline
Just get rid of the not-quick connect stock connector and just just AN fittings.
Old 04-09-2010, 02:14 PM
rzimmerl's Avatar
scAR'd
Quote:
How do you propose that using the stock plastic lines?
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
Kurt K's Avatar
Kurt K Kurt K is offline
Still slow
SCCoA Member #: 443
This is the one I'm using mounted in the stock location. I wrapped the filter in neoprene gasket material since it is slightly bigger than the stock filter and it is held in-place just like the stock filter. Mine currently has -6 AN connectors, but I will be changing them out to -8 AN connectors. I don't see those AN options listed on their website though anymore.
http://www.sx-performance.com/Fuel_Filters.htm
Shouldn't you be upgrading your fuel lines too?
__________________
Kurt K (e-mail)
SCCoA Member #: 443
2 '89 XR7 5spd's -- on their way out, really! Any Offers?
  #5
Old 04-09-2010, 02:28 PM
rzimmerl's Avatar
scAR'd
I'm still up in the air about line upgrade. Seems stock lines are -6 and work fine for quite a few people. Been looking into a BAP also, not sure if I'll need the dual pumper setup
Would an -8AN compression fitting adapter work safely on the pump hat outlet? Then that leaves the return stock, or does that need to go larger also?
Found these fittings also that should go right onto the pump hat if I use -6 line.
http://www.summitracing.com/parts/RUS-640850/
http://www.summitracing.com/parts/RUS-640860/
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
  #6
Old 04-09-2010, 03:13 PM
rzimmerl's Avatar
scAR'd
Another question is how many GPH are needed for the filter? The one I posted flows 130GPH.
Answered my own question 130GPH converts to 492LPH, and a 255LPH pump converts to 67GPH
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
Last edited by rzimmerl; 04-09-2010 at 03:30 PM.. Reason: answered my own question.....
  #7
Old 04-09-2010, 04:08 PM
David Neibert's Avatar
David Neibert David Neibert is offline
Still loves the Cobra Rs
SCCoA Member #: 858
Ryan,
That filter looks perfect for the dual pump system that several of us are planning to install this year.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
  #8
Old 04-09-2010, 04:16 PM
rzimmerl's Avatar
scAR'd
Quote:
Originally Posted by David Neibert View Post
Ryan,
What size feed line are you guys going too?
They have the same filter but in a -8 version. http://www.summitracing.com/parts/RUS-650103/
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
  #9
Old 04-09-2010, 04:34 PM
SCCoA Member #: 858
Most likely dual 6AN supply lines and a single 6AN return line. When we did that on my turbo car I bought some generic high pressure fuel filters and cut the hose barb nipples off and added compression fittings and 6AN adaptors to each end. It was a real pain and it looked kinda rigged up.
http://members.tccoa.com/dneibert/dualpumps.jpg
__________________
  #10
Old 04-09-2010, 08:06 PM
rzimmerl's Avatar
scAR'd
Looks like the stock filter is 5/16 on both ends. I am going to order this setup and see how it works out. Worth a shot when a stock filter is now $15.
I'll update the post when I fit it up next week.
Ran across this deal in Jegs, buy the filter get spare element free. Its only 2-5/16 OAL also, same delivery specs as the Russell
http://www.jegs.com/i/JEGS/555/15030/10002/-1
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
  #11
Old 04-09-2010, 10:28 PM
I assumed but it in the stock location and totally remove the stock flexible lines and put in your own. I HATE those not-quick connector.
  #12
Old 04-09-2010, 10:59 PM
XR7 Dave's Avatar
XR7 Dave XR7 Dave is offline
ask questions-get beat up
SCCoA Member #: 1508
Those are 40 micron filters. I believe that 10 micron is recommended for fuel injection. But with 80lb injectors maybe it doesn't even matter.
"I do not have a narrow uritee. I could pass the child myself if I had to!"
__________________
Email me here.
  #13
Old 04-10-2010, 01:03 AM
rzimmerl's Avatar
scAR'd
Russell only goes down to a 40 micron filter, so do we really need the 10 micron?
I don't have 80's, only 60's so I won't be able to pass large kidney stones, more less a child...
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
  #14
Old 04-10-2010, 08:43 AM
XR7 Dave's Avatar
About fuel filters.
It says in there that 10 microns is the standard for automotive fuel injected gasoline engines. I've read that elsewhere also and Aeromotive sells a 10 micron filter but it's nearly $100 by the time you buy the necessary adapters, etc. 40 microns is for carburetors.
I think the reason that a 10 micron filter is so expensive is that the steel mesh necessary to achieve that filtration is expensive and takes up a lot of space to allow the necessary flow. A paper element is cheap and easier, but that wouldn't be cool in a 1000HP fuel system. The other (and probably main) reason that a steel mesh must be used in the Aeromotive filter is that it is also used for alcohol systems where the presence of water is common and water is death to a paper filter.
__________________
Email me here.
  #15
Old 04-10-2010, 10:31 AM
rzimmerl's Avatar
scAR'd
The Russell and the Jegs filters I posted both have stainless mesh for the filter element.
Here is an Aeromotive unit that filters to 10 micron, but it uses a paper filter not steel.
http://www.summitracing.com/parts/AEI-12301/
Here is another that is 10 micron with steel mesh, but pricey
http://www.summitracing.com/parts/AEI-12333/
I can see the need for a diesel engine needing the fine filter to remove the particles so that it does not damage the injection pump. Hence why diesels have more then one and large fuel filters.
I was at my buddies shop last week and they use 100 micron on their Supra's. They currently have run 7.80s in one of their cars. At their last race they had a guy that they believe clog the 10 micron filter and that caused the engine to go.
__________________
1990 SC AOD 1.7 AR
11.676 @ 121.35 mph
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
95 fuel filter ENCDEI97 Technical Forum 3 04-20-2003 09:26 PM
Fuel Filter Replacement cheeriosluvr Technical Forum 2 04-10-2003 03:34 PM
fuel filter smokymance Technical Forum 1 04-03-2003 08:16 PM
Fuel Filter Emergency TBirdBrian95 Technical Forum 2 08-27-2002 04:34 PM
Fuel Filter JimGravelle Super Coupe Club of Ontario 0 06-05-2002 09:55 AM
