Tiny leak
Hey guys my rad has a tiny leak about 4 or 5 inches from the cap.It's on the top and a little on the side I can get to it with out taking it out of the car ,would it behove me to soder it or get it redone or replace it.I've never had any problems with it before.Thanks JDC
I would replace it, if you want to try and fix give it a shot. But when you are out and about and it leaks again you will know why.
__________________
1993 SC / 5 Speed - with a couple of mods, see.member page 1951 Oldsmobile Restoration Blog: http://51olds98.blogspot.com/ Ashes to ashes, dust to dust. If it wasn't for Ford our tools would rust. |
You could try to solder it but it may be a job for the pros. My old radiator had a stress crack in the top tank which I repaired years ago by soldering a small patch over the crack. It held up over ten years until I replaced the radiator with an aluminum unit.
Personally I would replace the radiator like Flip suggests. I wouldn't run the risk of overheating the motor due to coolant loss. Others here on this site have had good success with the replacement radiators from Radiator Express. Bryan
__________________
-89 SC Loaded, Oxford White w/Shadow Blue leather interior, Garage Queen that never sees rain. members page -2003 Cobra, Red Fire, Blown 4.6L -1969 Cougar XR7 "R code", A true classic -2006 Hertz Shelby GT-H #0387, 1 of 500 produced |
Thanks guys I think I fixed itfor now but I am going to replace it.Like always thanks agin for the help.Have a great day ,JDC
| Thread Tools | |
| Tiny leak | JDC | Technical Forum | 2 | 08-04-2010 08:48 PM |
| coolant leak | ThunderDave | Non Technical Forum | 8 | 12-12-2008 02:33 PM |
| Bad MAF sensor or vac leak? | pablon2 | Technical Forum | 12 | 04-11-2005 02:07 PM |
| What happens if you use the old head bolts?? | 1991tbirdsc | Technical Forum | 8 | 06-26-2004 06:58 PM |
| Brake Fluid Leak | boosted89SC | Technical Forum | 2 | 04-19-2003 10:29 PM |
