#31
Keith: Thanks for the info and the sanity check....I definitely be making an upgrade.
Quote:
__________________
Brian Oatway '94 SC 2.6KB C4 Auto 10.917@124.56mph 514rwhp/460rwtq "Uber Club Member" SCCoA Member # 705 Last edited by SCrazy; 08-15-2010 at 12:15 PM.. |
#32
I just finished putting one in today. It took a little bit of smoothing out with a flap disc on an angle grinder and I had to put a little more bend in a few spots, but for how cheap it was, it worked out well.
$20 from Jegs. ![]() ![]() ![]()
__________________
CORN GAAAAASSS!!!
#33
I also finished putting my loop in today. I am about ready for the event; just a few more things to do.
Mike
__________________
1989 Cougar XR7 - Modified 1967 Cougar XR7 - untouched - 2011 F350 Crew Cab Superduty FX4 6.7 diesel 435hp/800 ft lbs torque 2009 Smart 2010 Harley Davidson Ultra Classic |
#34
that's a lot of nuts and bolts. I don't see any nyloc nuts either. Did you throw some loctite on those threads? Otherwise you may want to check them after the season to make sure none of them loosen up.
#35
The kit came with nuts, bolts, and lock washers. It has four pairs of holes, on each L-bracket to select which loop height you need.
__________________
CORN GAAAAASSS!!!
#36
I personally do not use only lock washers in an application I would prefer never comes loose. They simply are not effective.
http://www.eng-tips.com/faqs.cfm?fid=1257 |
#37
They're not as effective as nylon lock nuts are, but they certainly aren't zero. The spring like activity will serve as an added restraint as opposed to having nothing there. If it was only a washer with a crack in it, then that assumes there isn't any elastic memory in the washer itself. In the very least, it slows the rate at which the mechanical vibrations loosens the nut.
Anyways, I'll just keep an eye on it, regardless.
__________________
CORN GAAAAASSS!!!
#38
Check out this video showing a standard nut turning off a bolt when under vibration. then the next one showing a standard nut with a spring (split) washer.
http://www.boltscience.com/pages/junkertestplainnut.htm http://www.boltscience.com/pages/jun...ringwasher.htm I'm not sure I would be confident in saying a lock washer is better than nothing. In fact, information at the site above states: http://www.boltscience.com/pages/vibloose.htm Quote:
#39
It's cool, Mike. I looked at it as a conversation.
That's interesting stuff. Are the vibrations of the same magnitude in each test? I'm also a skeptic towards the split washers, but I have never assumed their effectiveness to be null. Thinking about it actually makes me agree with accelerating loosening of the nut or bolt. I give thought to many petty things, but not locking fasteners. Obviously nylocs aren't skeptical, once they're away from heat, at least. They're annoying to tighten, though. ![]()
__________________
CORN GAAAAASSS!!!
#40
yes, vibrations the same for each test. The company has something they call a junker which is a machine that is able to create shearing forces to duplicate vibrations over time but within a much shorter period. they've tested a number of fasteners and locking devices.
Their double nut test was pretty interesting as well. http://www.boltscience.com/pages/twonuts.htm |
#41
Funny I read all this, I also just installed a Summit Racing brand loop just like the one Casey pictured. Had an issue with it hitting on my exhaust under load, nothing a large pry bar didn't help.
Mine however did not come with lock washers, just serrated nuts which had the washer built it. I'm not to sure how good I feel about that but I plan on checking them after awhile. |
#42
Also, just to poke fun on Mike
![]() I read your sig 93 SC - before: 275hp/343tq 13.709 @ 104.25 After: 441hp/462tq Best so far 13.449 @ 111.59 I think you need to spend more time at the track and less time researching fastener vibrational loosening. |
#43
I need to install one on mine. Your car in canton? Mine is in AK right now.
#44
Yeah...........dork!!
__________________
CORN GAAAAASSS!!!
#45
Quote:
| Thread Tools | |
| Help on diagnosis | nczimmerman2 | Technical Forum | 10 | 02-01-2009 12:09 AM |
| AN fittings/hose ends, Driveshaft Safety Loop, 4.6/5.4L Performance parts, etc. | racecougar | Parts for Sale | 3 | 12-13-2008 04:07 PM |
| NHRA releases inital findings from tragedy and changes distance from 1320 to 1000ft | Jim Demmitt Jr | Non Technical Forum | 2 | 07-02-2008 11:01 PM |
| NHRA RULE CHANGES FOR 2006 (pay attention nitrous guys) | Kurt K | Non Technical Forum | 18 | 07-06-2006 02:40 AM |
