Go Back   Super Coupe Club of America Forums > Classifieds > Want to Buy
User Name
Password
Reply
Old 08-17-2010, 10:52 AM
needaSC89-96 needaSC89-96 is offline
SC Newbie
Please help with a sc
Hello so I had a sc about ten years ago and loved and I found one with a 160000 miles on it 2 ownes last owner had it 14 years all original no work has ever been done besides oil changes and tires paint is perfect no rust at all.
Now the bad is a really bad banging in the front I am assuming its shocks and struts so can anyone help me out its 1700 dollars it runs great but for how much longer do you think with that many miles I need it to last atleast a year till I get my house with a target to take care of her so again please post or pm me and let me know what to look for and what I'm getting into
Old 08-17-2010, 12:15 PM
S_Mazza's Avatar
S_Mazza S_Mazza is offline
SCCoA Member #: 2821
These cars can last a long time, although some maintenance will be required. That's a given. Front suspension usually needs parts around 100,000 miles. If the front suspension is all original, your mileage is pretty high.
To start with, when do you hear banging? What is the quality of the sound? Is it a hollow knocking? Any pattern to it?
If you want to start inspecting things, just find a spot to lay next to the car and check the following:
1.) Rubber boots at upper ball joints, lower ball joints, outer tie rod ends, and sway bar end links. (This makes 10 boots in all.) If the boots are torn, the joints are probably bad or getting there.
2.) Movement at ball joints. Grasp the sway bar end links with one hand and try to twist. If it feels loose, it's probably bad. It should have a certain amount of tension to it. I can't really describe the proper amount, but if it is bad, it should be obviously loose. Do the same thing with the outer tie rod ends. The upper and lower ball joints, you can't really check this way. But you can jack up the car and use the tire for leverage. Grasp the top and bottom and try to "rock" the tire. Looseness here means you probably have a bad ball joint. Next grasp the sides of the tire and try to rock it. Looseness here means you probably have a bad tie rod end (inner or outer). Looseness in both directions means you probably have both of those OR a bad wheel bearing.
3.) Worn or cracked rubber bushings. Some of these are hidden from view with everything assembled, so just check the ones you can see for now. That includes the bushings where the tension strut meets the lower control arm and where it meets the frame. (4 locations total.)
The suspension parts for this car are not too expensive. (With the possible exception of the tension strut bushings, for which OEM is the only type that seems to last.) They can be difficult to change if the fasteners have been left in place for 20 years. But that would apply to almost any car.
__________________
God bless!!!
1990 SC auto ... red outside, gray cloth inside ... ~180,000 miles (and climbing) ... driven daily!
Old 08-17-2010, 12:33 PM
90coug's Avatar
90coug 90coug is offline
Huntin' for Stoich
SCCoA Member #: 2682
Send a message via MSN to 90coug
Not sure if S_Mazza mentioned but check your subframe to frame bolts, they like to work loose and will also cause a bang sound when hitting a bump. My Cougar would do this all the time when crossing the sidewalk to enter my driveway.
__________________
'95 SC
Garage
Old 08-17-2010, 02:03 PM
SC Newbie
Thanks so you think I should grab it? Its a 5spd and it felt strong you think the motor will last a bit? How much am I looking at to have the motor rebuilt and to do all the suspension myself? Thanks guys all your information is very helpful
  #5
Old 08-17-2010, 07:32 PM
JJP90SC JJP90SC is offline
93 5-SPEED
SCCoA Member #: 3074
Question Punctuation?
Over 130 words in this post.
Punctuation: 1 period!!
Very hard to read, that's for sure.
  #6
Old 08-17-2010, 08:06 PM
SC Newbie
Wow really tho that's what you have to reply with. How about I'm on my phone and can't see it that well thanks ~~~ hole..... ....... .... happy
  #7
Old 08-18-2010, 12:42 AM
scskydivin's Avatar
scskydivin scskydivin is offline
10 year sc owner
SCCoA Member #: 3774
ha ha, you gotta admit that was kinda funny.
__________________
1994 white sc
10 year sc owner
View http://www.sccoa.com/forums/garage_v...vehicle&id=107
UP THE IRONS!!!
  #8
Old 08-18-2010, 09:20 AM
93 5-SPEED
You really shouldn't text while driving!
  #9
Old 08-18-2010, 10:54 AM
90coug's Avatar
Huntin' for Stoich
Don't mind the complainers, some have nothing better to do than b*tch.
Back to the original subject, yes you should buy it you'll be glad you did.
__________________
'95 SC
Garage
  #10
Old 08-18-2010, 12:31 PM
SC Newbie
Lol I said I was on my phone not driving................. now back to the my question I want to buy it but how do you think I'm looking at to have the motor rebuilt if I pull it and reinstall it myself and how much in parts to do the suspension. 90coug being that your the only person that answered the question at hand. Thanks...........
  #11
Old 08-18-2010, 01:23 PM
90coug's Avatar
Huntin' for Stoich
Contact XR7 Dave, he will have the rebuild kit you're looking for and can quote a better price than I can. The suspension, well I'm not sure. Out of four mn12's I've owned I've never really had any issues with the suspension. Are you sure that it's the culprit?
__________________
'95 SC
Garage
  #12
Old 08-18-2010, 02:05 PM
BirdofPrey97's Avatar
BirdofPrey97 BirdofPrey97 is offline
Race the other guy
SCCoA Member #: 3187
Upper & Lower control arms Uppers are about $65 each, Lowers around $60 $125x2=$250
Inner & Outer tie rods about $10 each and there are 4 =$40.
Look those prices up on www.rockauto.com
Look at the boots and see if they are torn on the ball joints. See if they have grease in them.
I would state your location and you might get a local guy to come help you look at the car.
Pop the hood on the car and push down on the front fender on each side and watch the shock support. If it stays put that probably isn't the noise, but if theres day light or it moves around that could be the noise maker. If the mounts and shocks are shot you are some where around $600-$800 depending on what all parts are needed.
Hope that helps.
__________________
Honor, Grace and Dignity......Remember these
  #13
Old 08-18-2010, 02:57 PM
DrFishbone's Avatar
DrFishbone DrFishbone is offline
SC Surgeon
SCCoA Member #: 2325
Motor rebuild prices will be all over the place depending on who does it and what they do.
__________________
Matt Haub
2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ
Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph
Red '93 Auto
2003 Mustang GT Convertible
White '89 5spd
  #14
Old 08-18-2010, 03:51 PM
SC Newbie
Thanks everyone I'm going get it and hope she's good to me.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
