User Name
Password
Reply
Old 09-02-2010, 04:11 AM
unrapit unrapit is offline
If you have a stuck crank bolt I have the tool to remove it!!
My bolt broke off in the crank and I had to drill it and use an e-z out to remove it.I have my own lathe so I built a jig that fits on the crank so it can be drilled in the center.You can do this in the car without removing the radiator.Just the fan I removed.Works great!If anyone needs to use it let me know.Thanks
Old 09-02-2010, 08:11 AM
sinhumane sinhumane is offline
<---- this guy... i got a 95 with a limp crank pulley. i get home from iraq around the end of october. will get with you then.
Old 09-02-2010, 05:49 PM
92sclikenew's Avatar
92sclikenew 92sclikenew is offline
Send a message via AIM to 92sclikenew
Quote:
should tho some pics up..
i dont need to tool but would be cool to see what its about..
__________________
92 http://www.sccoa.com/forums/garage_v...w_vehicle&id=8
91 http://www.sccoa.com/forums/garage_v...vehicle&id=228
SCCoA Member #: 3641 Join Date: Oct 2006
Quote:
Originally Posted by XR7 Dave View Post
Cool stuff isn't cool if your junk is still slow.
Old 05-19-2012, 07:14 PM
sts70004 sts70004 is offline
Old post I know but what I did was wrap the drill bit in paper till it fit snugly. Worked perfect
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
just my luck (crank bolt) 93thunderbird Technical Forum 8 07-05-2005 08:58 AM
balancer replacement madstyle51 Technical Forum 5 03-29-2005 12:03 AM
Crank Bolt 91_SC_BIRD Super Coupe Club of Ontario 17 02-08-2005 01:08 PM
Broke crank bolt, Can I replace just the bolt? Bigme574 Technical Forum 3 09-21-2004 11:32 PM
Crank bolt specification??? LJGriggs Technical Forum 4 06-08-2004 03:12 PM
