#31
yes novcnt is the update counter
correct, make sure your not getting torque multiplication from the converter I.E. make sure its locked so if you cruise at 60mph and your engine speed is 2,760 rpm 2760/60=46 your new nvbase value the constant is the value of nvbase x novcnt in this example, 46 * 4 = 184 nvbase_x_nvc new value should then be set to 184 this is how the ecu calculates vehicle speed from the vss input doing the aforementioned will have the ecu speed calculation correct the shift points other than WOT are interpolated in the sealevel shift functions. I usually dummy it down to 2 points to make it easier to calculate, also reduces the chance of a mistake like having the downshift speed higher than the upshift speed which is a common mistake when folks try to reiterate the shift schedules. |
#32
Bump time, if I am understanding this correct somebody with an AOD Thunderbird can swap in a 4R70W without having to use a stand alone controller? You just have to do some things with the wiring harness and get a QH?
#33
No, that stuff is not in the AOD cars' computers. You would need to swap to a 94+ computer.
__________________
God bless!!! 1990 SC auto ... red outside, gray cloth inside ... ~180,000 miles (and climbing) ... driven daily! |
#34
Quote:
I think Dave Neibert looked into this and decided it was much simpler to use a stand alone system. I had implemented a 4R70W into my '92 5 speed using a pretty advanced stand alone system from Powertrain Control Solutions (pricey).. But they now offer a simpler version that doesn't require a laptop. Just plug it in, and adjust dials for shift firmness and shift points. It is more affordable too. Check out www.powertraincontrolsolutions.com Jeramie
__________________
1994 Thunderbird SC Auto #2 - 45k original miles. 1994 Thunderbird SC Auto #1 - Police package heads/96 N/A motor test mule. SOLD 1992 Thunderbird SC 5 speed. Mostly stock now, former 345.5 rwhp/402.8 rwtq monster. - SOLD after 12 years of ownership ![]() 2000 Grand Prix GTP -Turbo conversion, billet precision 5858 CEA turbo .63 T3 hotside. Stock supercharged longblock with N/A top end, numbers coming soon. |
#35
I was hoping you'd chime in Jeramie. Did you solve your shift flaring when you had the 4R70W?
#36
Quote:
I never had the flare problem with the stand alone in my '92. Nice thing about the stand alone is that it doesn't use a VSS sensor, so that means you can put even the latest/newest 4R70w's without regard to if they have vss teeth, or how many vss teeth they have. The stand alone simulates a vss signal for your speedo and EEC input, and the output is adjustable so you can recalibrate your speedometer and make it exact. Jeramie
__________________
#37
Thanks Jeremy. I was worried that the PCS controller was the cause of the issue through some software limitation. I'm fairly positive I'll be making this swap at some point in time in the near future. I did notice that they now offer two controllers. Any thoughts about the differences?
http://www.powertraincontrolsolution...impleshift.php vrs http://www.powertraincontrolsolution...anscontrol.php Last edited by Toms-SC; 02-14-2012 at 06:41 PM.. |
#38
If you end up doing it, feel free to give me a call. Their new simple version is pretty cool, but I really liked having "full control" of everything on the full version.
That whole stand alone setup is on my best friend's '93 SC now, so I still get to tweak with it (when his car is running, LOL).. I have several calibration files I could share to get you started, and I can save you lots of time setting it up. The full PCS controller like I had is extremely powerful, auxilary inputs, outputs, etc.. You can use it to control various other non-transmission related things too.. Like using an ACT input to turn on your intercooler fan at a certain ACT temp. It also can act like an RPM/WOT window switch for nitrous., you can use the outputs to illuminate an indicator light, or trigger a relay for various things, and control their operation with the software. Very, very powerful.. Especially when you tap into the resistor based cruise control switches, and use them for manual shifting/manual tq converter locking, etc.. I could go on and on.. One guy used it on his Cobra, and used his ABS inputs to enable a boost-bypass solenoid controlled traction control, which opened the boost bypass valve a certain amount per % variation of wheel speeds comparing the front and rear axles. Outputs can be analog, digital, or PWM. Again, very powerful Jeramie
__________________
#39
The $750 version is the one I used, and was describing above. The simple version looks neat, but you get so much more technology in the $750 version.. It all depends on what you want out of it.
The advanced version allows you to change between two different calibrations as well. Have a soft shifting, fuel economy mode, then a track or performance mode at the flip of a switch. Did you ever see my videos of it in operation? See here: http://www.sccoa.com/forums/showthre...ht=4r70w+video Jeramie
__________________
1994 Thunderbird SC Auto #2 - 45k original miles. 1994 Thunderbird SC Auto #1 - Police package heads/96 N/A motor test mule. SOLD 1992 Thunderbird SC 5 speed. Mostly stock now, former 345.5 rwhp/402.8 rwtq monster. - SOLD after 12 years of ownership ![]() 2000 Grand Prix GTP -Turbo conversion, billet precision 5858 CEA turbo .63 T3 hotside. Stock supercharged longblock with N/A top end, numbers coming soon. Last edited by 92bird; 02-14-2012 at 06:56 PM.. |
#40
I'm definitely doing this swap after I get my 89 sc running good. Hopefully soon
#41
What transmission harness can you use, I found 97 Tbird 4.6 trans harness on ebay or does the PCS system come with a complete harness?
#42
Alan,
What would it take for an ~'03 4R70W to be beefed up to handle 450rwhp and 450rwtq behind an AR car? I found quite a few trans local from $175 for a 155k 2002, $350 for a 45k 2003, and up to $600, all are 01-03 V6 Mustangs. |
#43
Quote:
97 and prior trans needs a 97 and prior harness.. 98+ trans needs a 98+ harness. I think I have a spare unmolested 98+ mustang trans harness in my storage.. If you want it - send me a message and just pay shipping and its yours. At 450whp/450wtq a stock late model 4R70w with just valve body modifications/accumulator mods (j-mod) would probably hold up fine.. But there are certain long term reliability issues, and many improvements that can be addressed in an overhaul. Don't overlook a good converter either.. I used an updated 2004 factory mach 1/marauder converter and it made a great street converter. A little tight for the track, but plenty to boil the tires on the street. I'll leave the converter recommendations to Alan, as he's the expert, and who I will go to for my future converter needs. Jeramie
__________________
#44
Ryan,
If you are seriously pursuing this swap as well I think we should attempt a group buy on the PCS controllers. I suspect that 4R70W swaps are going to be the 'new hot ~~~~' as people attempt to maximize the power they are producing. |
#45
Not contemplating the swap at the moment, but more of a long term project. I may start to purchase items little be little, since my current AOD is holding up.
Jeramie thanks for the reply I may take you up on that harness. Also can the AOD shifter be used or does a 4r70 equipped car shifter need to go in along with the matching cable? I planned on having Alan go thru it if I did the swap and spec the converter. |
| Thread Tools | |
| 1997 thunderbird 4.6 to 5.4 swap. | DSM | Technical Forum | 10 | 09-14-2010 01:45 PM |
| Just a thought about transmissions...AOD swap to 4R70W in 89sc, possible? | phils89sc | Technical Forum | 5 | 05-17-2010 05:23 PM |
| Question on 2003 mustang 4R70W swap into 94 sc | 92bird | Technical Forum | 11 | 01-21-2010 02:51 PM |
| 4R70W Mustang swap? | Blown 91 Bird | Technical Forum | 5 | 12-20-2005 08:52 PM |
