engine block plate
Just curious about the engine block plate (the steel plate between the motor and tranny). 3.8 and 5.0 the same plate/interchangable?
thats a somewhat good question. i know the trannys are but not sure about the plates. if all else fails use a good grinding bit and make it work.
I am not sure about between a 3.8 and 5.0
However I did take an eninge out, ( at a u-pull-r-parts) and it was of an auto car.. and that plate between the Transmission and engine I was told is different between an Automatic Transmission, and a Manual Transmission. Automatic being of Thin Aluminum Manual being of thicker Steel I believe. So with that... if you are looking for one to modify (if needed) for the 5.0 be sure to find one from an Automatic.... It will be easier to work with. Karl
__________________
1989 XR7 Red 5spd |
Quote:
#5
i have a 5.0 plate from an auto car, i can get a pic of it tomorrow.
#6
Quote:
I can try to get a picture of it tomorrow for you.. I think they are the same design... just the 5spd plate is more heavy duty..
__________________
1989 XR7 Red 5spd |
#7
This is the Thicker 5spd plate...
It has been sand blasted and painted with aluminum colored paint. Karl
__________________
1989 XR7 Red 5spd |
#8
Quote:
#9
Quote:
It is the floor of the Storage unit I have... ![]()
__________________
1989 XR7 Red 5spd |
| Thread Tools | |
| Aligment. Problems Still.....ARGH | ricardoa1 | Technical Forum | 199 | 05-12-2010 07:26 PM |
| Inlet plenum EGR block off plate | talon660 | Want to Buy | 4 | 04-26-2006 02:59 AM |
| 4.6L engine to M5R2 tranny adapter plate? | quick35th | Technical Forum | 11 | 01-23-2005 04:25 PM |
| For Sale: 89 SC engine block & parts | Wayne Ing | Super Coupe Club of Ontario | 4 | 06-22-2004 08:31 PM |
