Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 04-06-2011, 02:58 PM
XR7-4.6 XR7-4.6 is offline
SC Newbie
Send a message via Yahoo to XR7-4.6
How to add cruise control illumination to 94/95 SCs
As most of you know or have found out after trying to replace nonexistent bulbs, our interiors lack a lot of illumination that is normally found in modern cars. The MN12 existed right between the era of having to flip on the map light to see what button you’re pressing and the current era of having to adjust the dimmer so the backlighting from the “trunk release” button doesn’t blind you. From the bare bones functional sense you can confidentially use the radio, adjust the climate control, operate your windows/locks, and see all of your instruments. Anything else like cruise, headlights, mirrors you’ll have to sense and live with the rather incomplete looking lighting scheme. Until now.
WARNING: This is not for the faint of heart, you will have to live with a two things after this conversion:
1) You will not be able to use a single part from your existing steering wheel other than your airbag, even the hardware is different.
2) The illumination is limited to blue. The buttons are molded in translucent blue and painted black from the factory.
If these aren't a concern, read on...
Mark VIII's received cruise control illumination from the 1995 to 1998 model years. They use a special clockspring with 5 (rather than our 3) active terminals (excluding key in input), the added pins are dedicated to illumination. The circuit itself has 1 small incandescent bulb per pod and 1 LED in the right side, the rest of the cruise circuit is virtually identical to the MN12/SN95. The buttons themselves are translucent and allow for light to shine through whereas the MN12 and SN95 buttons are solid black plastic with the lettering printed on them.
You could theoretically swap the complete steering wheel and clockspring from a mark VIII directly into your MN12 and call it a day, however the steering wheels are wrapped differently and don't match the grain of our airbags particularly well. The Mustang wheel on the other hand is finished identically to ours despite having completely different hardware and electronics inside them (See illustration). For this how to I'll be covering the latter since this project revolved around my FR500 steering wheel.
If anyone’s still wondering, the MN12 wheel and buttons unfortunately won’t interchange. The cruise mounting is different as well as minor proportions such as the switch plates, pivots and even the spacing between the spokes. It seems to be sheer luck that the Mustang switch plates and circuit boards interchange with the Mark VIII units. It appears that early on (93/94) they were 100% identical to the SN95 other than the bases. It’s a wonder why Ford didn’t equip the higher level Mustangs such as the Cobra with these considering the illumination note is even the same for the 94-00 Mustangs.
Tools needed:
-Phillips head screw driver
-Small flat blade screw driver (1/8 - 3/16 or so tip)
-Needle nose pliers
-Socket wrench with T50 Torx socket and 8mm socket
-Soldering iron and solder
-Shrink tubing and electrical tape
-An Electronic Vacuum Troubleshooting Manual would also be valuable to have.
Parts needed:
-1994-2004 Mustang Cruise equipped steering wheel and plastic shroud (the part between the column and airbag). If you too have been considering the FR500, now's a good time to grab one.
1994-2004 Mustang horn pads, wiring and hardware. I actually suggest sourcing these from a NON CRUISE equipped Mustang as they position the MN12 airbag much more flush with the wheel. The terminals also match the Mark VIII’s horn connectors better.
-1994-2004 Mustang cruise control buttons. Don't be too concerned about condition as you will only be using the mounting bases.
-1995-1998 Mark VIII cruise control buttons and wiring harness, don't worry if the mounting tabs are broken. (Note: Cruise buttons in these Marks were monochromatic so finding them in black can be difficult.)
-1995-1998 Mark VIII clockspring assembly and the pigtail from the dash harness
Converting the buttons:
Note: I AM NOT RESPONSIBLE FOR ANY DAMAGE THAT CAN RESULT TO YOU OR YOUR CAR.
Note: If you’re using a complete Mark VIII steering wheel, skip steps 1 through 5.
1) Begin disassembling your SN95 and FN10 cruise buttons by gently prying on the buttons at the pivot points. On the right pod be sure to remove the set accell/coast buttons before resume.
2) Carefully unclip the circuit boards from the bases and unplug the harness connector from the circuit. Mark the connectors and boards to help get the orientation right during reassembly. Discard the Marks bases and discard the Mustangs electronics and switch plates.
3) Run the Mark harness through the Mustang base and connect the circuit board. Before clipping it in you will need to clearance the base using the pliers to break off the alignment tabs and wire channel so the new circuits clear. Once everything’s out of the way clip them in
Note: Some Mustang bases have a smaller opening for the harness to go through, if that's the case enlarge it with a 1/4" drill.
4) Place the rubber inserts over the boards and carefully clip on the switches from the outside in.
5) Mount the buttons to the steering wheel and connect the horn terminals to each horn pad if you haven’t already. Set the assembled wheel aside for now as we move onto the chassis.
Note: The Mark harness illustrated had to be slightly modified as it only had 1 connector for the horn pads and two for grounds for some reason. If that’s the same case for yours simply cut the ground wire completely off (this won’t effect operation as it’s grounded through the cruise circuit) and splice in an additional connector pigtail to plug into the other horn pad.
Converting the car
6) Unhook the battery and let it sit for a few minutes.
7) Remove the round access covers on the steering shroud, unbolt the airbag and unclip the connectors. Remove the steering wheel after loosening the torx bolt retaining it. Also remove the column shroud, knee panel, and floor vent duct underneath the column.
8) Remove and replace the factory clockspring with the Mark VIII one.
9) Cut the stock pigtail off the dash harness and splice the Mark one in it’s place, just match the circuits pertaining to cruise and horn for now.
Note: viewed from open dash connector
10) For the remaining two wires you’ll need to tap into an illumination circuit in the dash, the illumination wires are usually LB/R. You can simply run the ground to the chassis or splice into another known ground, an EVTM is very handy to have for this step. (I tapped into an unused terminal in the secondary junction box for my illumination feed, again I strongly suggest an EVTM for this)
11) Shrink wrap and Tape up all of the exposed wires, connect the new pigtail to the clockspring as well as the 2 pin airbag connector and reassemble all of the parts removed in step 7.
12) Install the steering wheel, connect the white cruise connector to the clockspring, connect the airbag to the clockspring, reinstall the airbag
13) Connect the battery, turn on the headlight switch and drool over your new feature.
If anyone has questions/concerns or anything to add to this, feel free to PM me.
-Matt
Old 04-06-2011, 03:14 PM
90coug's Avatar
90coug 90coug is offline
Huntin' for Stoich
SCCoA Member #: 2682
Send a message via MSN to 90coug
Good stuff, thank you for taking the time to document this. Lights are always impressive
__________________
'95 SC
Garage
Old 04-08-2011, 10:13 PM
92bird's Avatar
92bird 92bird is offline
14+ year SC Owner
SCCoA Member #: 1200
Cool, I wonder if the pieces from an explorer would work too? The 95-?? models look similar to the late SC.
Mods like this are the coolest. Thanks for sharing!
Jeramie
__________________
1994 Thunderbird SC Auto #2 - 45k original miles.
1994 Thunderbird SC Auto #1 - Police package heads/96 N/A motor test mule. SOLD
1992 Thunderbird SC 5 speed. Mostly stock now, former 345.5 rwhp/402.8 rwtq monster. - SOLD after 12 years of ownership
2000 Grand Prix GTP -Turbo conversion, billet precision 5858 CEA turbo .63 T3 hotside. Stock supercharged longblock with N/A top end, numbers coming soon.
Old 04-09-2011, 04:21 PM
SC Newbie
Happy to share I love doing these kinds of subtle mods to cars, it makes everyone "in the know" take a second look lol.
I experimented some with the Explorer setup at the junkyards. The switches look the same but are WAY WAY different in terms of mounting and design, they use rubber buttons with integrated electronics and the bases mount specific to the steering wheel.
I think if you could swap wheels and clocksprings it would be a better option for most since you can change colors and better yet, easy to find. I'd just have to figure out out if A.The clockspring can be adapted like the Mark VIII ones and B. If the wheel mounts to the column the same as ours.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Cruise control Schematic 91 XR7 Technical Forum 22 08-29-2011 09:40 AM
Fuse for cruise control? fixmysc Technical Forum 0 09-25-2007 07:11 PM
Fixed Cruise Control on 89SC Eric Bryan Technical Forum 0 09-18-2005 12:24 AM
Cruise control Problems Pt 2 91 XR7 Technical Forum 5 06-29-2003 07:53 PM
