How to check a 5-spped tranny?
Hey guys,
I have a 90 SC 5-speed, and I am planning on going hunting at the local junk yards for a 5-speed tranny. Is there any way to inspect a transmission to see if it is in working order? Thanks. ![]() |
Nobody has any knowledge or experience with this type of situation?
I don't know if shifting through the gears would really tell you much. If you take off the top cover, you can slide the brass blocker rings (synchros) towards the gears and measure the tolerance. I forget what is the correct tolerance for low wear, but if they move a whole lot - maybe even touch the gear, they're worn out and it will not shift into that gear very well, if at all. If the shifter feels sloppy, it will need rebuilt...which is very common in junkyard sc's.
__________________
Matt Haub 2009 SS Champ ¦ 2010 Mod1 1st Runner-up ¦ 2011 Bracket 2nd Runner-up ¦ 2012 Bracket Champ Black '89 5spd - 266K miles ¦ RWHP: 301 RWTQ: 375 ¦ Best 1/4mi:13.011, MPH:107.18mph Red '93 Auto 2003 Mustang GT Convertible White '89 5spd My Garage |
Take the top cover off and inspect the blocker rings on each side of each synchronizer assembly. They are the brass gear looking pieces. They should all be fairly snug and not dangly or really loose, the 2 in the middle (2nd & 3rd gear) especially. If they are real loose the fiber lining is worn off and they'll crunch when shifting. They should snug up to the synchronizer but leave a gap when pushed up to the gear. Check the fluid color and clarity, it's red ATF, and inspect all the gears you can see for any damage. The front input shaft can wiggle side to side a little but not front to back. Hope this helps.
__________________
90 5spd, best E.T. 12.250 best 1/4mi speed 112.89 mph best dyno 388.42 rwhp 419.68 rwt 2004 Cadillac CTS, 14.616 @ 91.84mph. |
#5
Thanks for the info Mike....
![]() I have a 5 speed trans with a busted bell housing and was wondering how I could tell if the internals were any good.... ![]()
__________________
Flying is the 2nd greatest thrill known to man. Landing is the first !!!! Every day, I set a personal record for consecutive days I have remained alive! If you cut a crumb in half, you don't get two half crumbs, you get two crumbs Doesn't this violate some law of physics? |
#6
I've got a couple of spare housings if you need one.
__________________
#7
Let me pop the cover off this week end and see what I have....
__________________
#8
Quote:
I know its a big long shot, but would you by any chance happen to have a video that demonstrates this? ![]() Thanks, ![]() |
#9
No sorry, never thought to do a video but I've got a tranny open now I'm disassembling for parts that I could video. If I get a chance later this week I'll see what I can do.
__________________
#10
Quote:
"1. Inspect gear teeth on sychronizer ring. If there is evidence of chipping or excessively worn teeth, replace with new parts. 2.Inspect the sychronizer ring for wear. To check wear of the sychronizer ring, fit the sychronizer evenly to the gear cone. Measure the clearance between side faces of sychronizer ring and gear with a feeler gauge. If clearance is less than 0.8mm(0.031 inch), replace sychronizer ring. Note: First/second, third/fourth and fifth/reverse sychronizer-to-gear clearance specifications are all the same."
__________________
1989 Cougar XR7 5 speed black (R.I.P. 5-5-08) 1989 Cougar XR7 5 speed - white w/ blue interior Ported 89 blower, 5% od, gtp blower rotors, removed air silencer, manual steering rack, mp 10% crank pulley, 2 1/4" dual exhaust, ported 94 sc manifolds, ported 94 supercharger, tom morana "B" camshaft 13.909@98.65 13.606@100.64 |
#11
Okie doke, here's a quick video I made of what a good and bad blocker looks like.
http://s636.photobucket.com/albums/u...badblocker.mp4
__________________
#12
Nice video.....
I'll see if I can check my trans out this week end....
__________________
#13
Quote:
Do you still have the video? I wanted to share it with a friend but it said "video no longer exists" in the link. Thanks. ![]() |
#14
I just went to photobucket and recopied the link. The video is still there and this should work. In fact I clicked on the link in the post and it worked Ok.
__________________
| Thread Tools | |
| 94 SC Auto looking for better torque converter and tranny upgrades | blkbird95 | Technical Forum | 4 | 09-08-2006 02:38 PM |
| tranny help, mount, leak | GREATWHITE666 | Technical Forum | 14 | 05-27-2005 10:42 AM |
| Question on the tranny check balls.. | v8killr | Technical Forum | 1 | 03-30-2005 11:02 AM |
| Auto tranny stuff - long/tech | lazybird4pt6 | Super Coupe Club of Ontario | 2 | 03-04-2003 10:07 PM |
