Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
  #16
Old 05-29-2012, 06:53 PM
BLOWN38's Avatar
BLOWN38 BLOWN38 is offline
lookin good!
__________________
~Chris
SCCoA Member #1826
Riding jack stands.
  #17
Old 05-30-2012, 08:39 AM
shoalcracker shoalcracker is offline
I have have the same problem with latching the hood.
Broke both corner lenses screwing with it and all my banging and slamming.
Tried grinding and adjusting full travel on the latch to no avail.
Pls followup if you find a simple solution. Mine is still complete so getting in there is a challenge.
Paul
  #18
Old 05-30-2012, 09:06 AM
Kurt K's Avatar
Kurt K Kurt K is offline
Paul
There is no simple solution. I welded washers on the lower edge of my hood latch so I could raise it high enough to get it to latch. I also had to notch a slot out of the fiberglass near the hood latch opening of the hood. The reason for the slot is that the factory latch opening isn't big enough to fit over the fiberglass and metal backing plate of my hood.
The trick for me to get the latch lined up was by putting dabs of orange RTV where I wanted to check alignment, as well as making very small adjustments when I got close. When everything was finally lined up, I can drop the hood from about 6-8" high and it closes and latches every time.
__________________
Kurt K (e-mail)
SCCoA Member #: 443
  #19
Old 05-30-2012, 09:46 AM
mywhite89's Avatar
mywhite89 mywhite89 is offline
Send a message via Yahoo to mywhite89
Do you have hood pins also or are the welded washer sufficient to keep the hood from lifting? I may do the same type of thing so I don't have to modify the frame of the car.
chris
__________________
89 SC 5-speed 1.7 Autorotor twin screw over 425rwhp
95 SC auto mpx powered M90 310rwhp
92 SC Auto stock(just bought)
my email
  #20
Old 05-30-2012, 10:53 AM
Kurt K's Avatar
Quote:
chris
I do not have hood pins. There are pictures of my car in my garage page of my 92.
I have heard about hoods that have separated around the latch area and they still lost their hood (and usually windshield and roof)....hood pins are still probably a safer way to go. Plus, it is possible to retain the safety catch part of the latch and use hood pins. But like you, I like the smooth look of the hood without pins.
__________________
Kurt K (e-mail)
SCCoA Member #: 443
  #21
Old 05-30-2012, 11:07 AM
S_Mazza's Avatar
S_Mazza S_Mazza is offline
The bodywork and paint look very nice!
I would miss the old hood, though ... it's such a smooth design!
__________________
God bless!!!
1990 SC auto ... red outside, gray cloth inside ... ~180,000 miles (and climbing) ... driven daily!
  #22
Old 05-30-2012, 03:40 PM
mywhite89's Avatar
Quote:
Tell me about it, I already do. I might have it painted also in case I can go back with the stock hood some day.
chris
__________________
my email
  #23
Old 05-30-2012, 03:52 PM
Quik95SC's Avatar
Quik95SC Quik95SC is offline
Hood not a problem
Latching this hood is a big problem, we will need to create and weld a bracket for the factory hood latch that will secure it to the frame at least an inch higher than is possible with the factory bolts. I really don't want hood pins on this car at all.
chris
Chris,
I don't have hood pins on my car and I have the same hood as you. I did have to slightly modify the hood latch and and I can't use the slider bar above the PS headlight but once I pop the hood from inside I can easliy reach up and move the sliding latch by hand.
Like Kurt said I had to file the hook part of the latch itself to fit into the opening in the hood and metal backing plate, but not much else other than that. I have had mine for about 3 years now and have had if off several times and it always bolts right back in place with no alignment issues as far as I can see. May have gotten a good hood and a lucky fit from the beginning, who knows. If you would like further pics on the latch up close let me know and i can take some with my cell and send them to you anytime.
Here is a link to how mine looks:
http://www.sc-shootout.com/Gallery.p...=picture&id=60
http://www.sc-shootout.com/Gallery.p...=picture&id=63
http://www.sc-shootout.com/Gallery.p...=picture&id=61
Good Luck,
Smitty
Color looks great BTW!!
How much pearl did you add to the paint/clear??
__________________
White 1994 Auto SC......................No ET
Venetian Blue 1995 5 Spd...............No ET
Orange Crush Pearl 1995 Auto SC........12.158 @ 108 MPH
355 RWHP 391 RWTQ
2011 SC Shootout MOD 2 Winner & Track Champion!
2012 SC Shootout MOD 3 Winner
Garage:http://www.sccoa.com/forums/garage_v..._vehicle&id=13
  #24
Old 05-31-2012, 01:40 AM
Kurt K's Avatar
Here's a picture of my installed modified hood latch. The yellow arrow points to the factory lower edge of the latch.
Click image for larger version
Name:	Hood latch modification rev1.JPG
__________________
Kurt K (e-mail)
SCCoA Member #: 443
  #25
Old 05-31-2012, 12:47 PM
Hopefully i'm not stepping on the thread.
Tks for the input and followuo Kurt.
I have shims down low on the latch to change the angle more towards the windshield.
I took a second look yesterday and I am going to drill out the existing latch plate in the hood, grind down the fibreglass apprx 1/8" and reinstall.
Pretty sure that will snug things up.
Paul
  #26
Old 05-31-2012, 03:03 PM
mywhite89's Avatar
Thanks for the picture, that should help things.
__________________
my email
  #27
Old 06-17-2012, 05:14 PM
mywhite89's Avatar
heres some before and after pictures from saturday. We made some moves this weekend. Have the top of the hood and the rear spoiler left to paint only. Took a long time to fit the hood and get everything positioned nicely. Starting to look like a car again though.
Chris
ID:	53454   Click image for larger version
ID:	53455   Click image for larger version
ID:	53456   Click image for larger version
ID:	53457   Click image for larger version
__________________
my email
  #28
Old 06-17-2012, 08:06 PM
Tim Groth's Avatar
Tim Groth Tim Groth is offline
Looks great! Nice work.
-Tim
__________________
Current Collection
1994 Thunderbird SC - Auto - Now 5 Speed
1995 Thunderbird SC - Auto
'90AOD / '90M5R2 / '944R70W - Parts Cars
Mn12parts.com - My parts website
  #29
Old 06-17-2012, 09:39 PM
Jason Wild's Avatar
Jason Wild Jason Wild is offline
Send a message via ICQ to Jason Wild Send a message via MSN to Jason Wild
looking good.
  #30
Old 06-19-2012, 09:56 AM
David Neibert's Avatar
David Neibert David Neibert is offline
SCCoA Admin
Chris,
Car looks great ! Are you going to paint the door trim to match the body ?
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
'Prepping for paint job' questions... Kit Sullivan Technical Forum 56 03-08-2007 03:01 PM
HAS/WOULD anyone let MAACO paint their SC??? sizemoremk Technical Forum 25 04-11-2003 07:43 AM
