Distraction Project - Garage subpannel
The honey has been wanting to do some home renovation as of late, and before she starts knocking down walls, I needed to get a nice safe power supply in place for my garage.
![]() 26 FT of THHN 6Gauge wire out to through the wall to the garage. 2-Black 1-White, and a 10Gauge green ground wire for the pannel ![]() I had to use about 30 zip ties to get the wires to forget they weren't on a spool anymore, and should lay straight. ![]() The old fuse pannel. I had to delete an ADT Alarm breaker, move the basement lights to it, pull off the garage plugs, shuffle some breakers, and open up a space for my two 110 phases. ![]() My new EATON subpannel in place, with the wires all connected ![]() The first line (Garage plugs) terminated and operational! ![]() Nice and happy ![]() Total cost: $180 (Wire, subpannel, food) Total time: 4:00 |
You'll love the subpanel. I installed one when we built the house last summer, ran 100 amp capable service to the garage. Added a 60 amp breaker to the house Eaton panel, 2 gauge feed to the Square D garage panel. The wire was a killer at over a buck a foot.
I went overkill when I built my garage 5 years ago...200 amps in the house, 200 amps in the garage
__________________
Kurt K (e-mail) SCCoA Member #: 443 '92 SC AOD -- 11.521s @ 116.748mph, 2.0 AR power . . . . . . . . . -- 13.547s @ 101.01 mph, only w/ bolt-ons '95 SC 5spd -- All Stock, except 17" Simmons wheels. '90 SC 35th Anny 5spd -- 3rd owner, 16k miles 2 '89 XR7 5spd's -- on their way out, really! Any Offers? |
soooo you just ran THHN through a hole in the wall then sleeved it with no connector ?? TISK TISK
#5
amazing that people do very stupid and possible deadly things, and have not a clue about either. please buy a book, talk to someone that knows, or call a professional.
the list is to long to explain the probs w/ ur install. sorry to be so rude, but just plain stupid in my opinion!!ps i have some grounds to make this statement; 22 years as a licensed electrician, brian |
#6
Quote:
#7
glad to hear!! again sorry to be so blunt
make sure to put a nm cable conn on your garage ckt if you havnt already. it appears you have a 100a service. if time or money allows you might want to consider upgrading it to a 200a.again sorry if i was rude,dont even have an sc anymore. just bunch of nice people and info/stories on here,that i get on dailyto read. would hate to read that someone or their family was hurt or worse and i didnt say something. brian |
#8
Hey, no hard feelings here. I was doing it wrong! You're right about the 100 amp main. Finances don't allow right now, so I'll have to be good and watch what I use
#9
I was surprised to see you knew to isolate the Neutral from the ground but ran the thhn like that.. cool deal with you doing the right thing and putting it in pipe. I only saw that done once, somebody ran 6g green wires down a wall onto a light switch. he screwed the switch to the sheet-rock with no box...
#10
personally I would have put a main disconnect in that subpanel so I don't have to go inside and cut the breaker for the garage to cut power to the subpanel. I know it's only required for disconnected structures, but it's a nice add on even if the subpanel is in an attached structure.
__________________
90 SC AOD 93 SC 5spd -441hp/462tq *SOLD* |
#11
Quote:
I installed a sub panel in my 1st garage and basement of 2nd house. I recently paid to have the sub panel installed in the basement of my 3rd house and they all have a main disconnect in the sub panel. The 2 sub panels I installed I had a certified electrician (friend) approve the work. ![]() |
#12
Quote:
__________________
| Thread Tools | |
| The SCCoA Garage is OPEN! | Pat DiPersia | sccoa.com website | 36 | 07-31-2012 10:59 PM |
| 2011 Makeover project (back in its own garage!) | neverfastenough | Non Technical Forum | 122 | 07-21-2011 02:56 PM |
| recent project in the garage | BRIAN WALTER | Non Technical Forum | 3 | 05-04-2011 10:13 AM |
| MN12 AWD Restoraton Project T-Shirt Design | 1HUMINBIRD | Non Technical Forum | 30 | 01-31-2008 01:33 AM |
| 95SC 2.2L supercharger project (pics included) | 93 Mark VIII | Technical Forum | 230 | 12-19-2003 09:06 PM |
