I've been stranded by my SC!
This hasn't happened to me in years, being stranded by a SC. Really hasn't happened to my much at all, but it happened today.
Here's the whats-what. Fraser's old car has been running good, not great but good. I'm getting poor gas millage, but that is most likely because I asked Fraser to "de-tune" it for 89 octane. After drives when the car gets warmed up, I get the ever frustrating "hot start" issue. Which I still haven't got nailed down yet. That's not today's problem(at least I don't think it is). After starting the car, and clearing off all of the snow I start my drive to work. The car needed one blip of the throttle while clearing the snow off. That has been normal for this car, it won't stall out, just the idle drops very low, and the car fights to stay running. One blip and all is good after that. So I do the short drive to reach the on ramp, get onto the highway, no issues. After maybe 1-2 minutes of 100 km's(1800 RPM, 5th gear) driving the car starts to BUCK, I quickly push in the clutch, the bucking is not in the drive lina, as I can not feel it after clutch is depressed. I look at all gauges, no CEL or upshift light. Aftermarket oil pressure is still reading 58-60. Wideband is reading between 18-20(that's what is stays at while cruising), tach is working, but I can see it jumping up & down in a range of about 400 RPM. No smells of coolant threw the vents, or burning oil anywhere. I pull off the highway, and limp back home, with the car bucking with any type of throttle, I never even tried WOT for the bucking reasons. Got back home, pulled into he driveway, guess what, bucking was gone. ![]() ![]() I 1st thought I broke the balancer, until the bucking went away when I got home. It could be on it's way out, or the bolt has broken off. Yesterday I filled the car with gas, it was VERY empty, and I had it sit all weekend with no gas in the tank. It could be the fuel pump(as I don't the age of it, or what one is there,stock or bigger). I know I could have picked up some crap with the low gas level. Without the CEL, or upshift light coming on, I'm sort of lost as to what this could be. Taking the morning off to see if I can find the trouble. ![]() Any input would be great guys, thanks. |
Bottom feeder gas? How's it run with fresh fuel cursing through it's veins?
I had a '90 that gave the same symptoms, but the car would eventually stop running, and usually when I was on a 400 series highway boxed in by dividers....scary place to be. ![]() It ended up being the heat sink compound under the DIS module. Over time it leaks out and then the module overheats and shuts itself off. Once the engine cooled down (and an SC engine takes eons to do that) all was good. It took forever to trace it, but I picked up some heat sink compound from Radio Scrap, layed it on the DIS mounting surfaces and never had that issue with that car again. Bruce |
I had the same kinda crap happen to me befor. It would buck really bad but I had no CEL. it would be fine then start bucking reallllllllllllllly bad nomatter what throttle, sometimes even just rolling down the highway with foot off the gas. It ended up being one of the wires were a littttttttttttttle loose on my DIS.
Seems like an overly lean condition. I know you say 18-20 is what your AFR normally shows, but I can tell you that is too lean. That said, maybe you have an exhaust leak causing that not to read correct.
Some things I've seen cause that. #1 - worn through wires on the o2 sensor leads grounding out on the chassis while driving. #2 - Something in the fuel tank or fuel filter restricting flow. Both of the above result in an overly lean condition which creates extremely inefficient and hot combustion resulting in a car that is bucking.
__________________
90 SC AOD 93 SC 5spd -441hp/462tq *SOLD* |
#5
I would start with the fuel filter. Had a similar situation with my F150. Fuel filter fixed it. Check items that others have mentioned, of course, but it sounds like a fuel starvation problem. With running low on gas, you may have clogged the fuel filter and now its junk.
Hope you get it fixed. |
#6
Quote:
GL -B
Previous Thread
Next Thread
