User Name
Password
Reply
Old 02-22-2012, 07:46 PM
jeymie'sSC jeymie'sSC is offline
SC Newbie
Ignition control module
Can someone comment on exactly what the function is for the "ignition control module"???? I have a 89 SC
Thanks
Old 02-23-2012, 12:27 AM
RalphP RalphP is offline
Old Fogie
SCCoA Member #: 3788
Quote:
Thanks
It fits in the distributor and, with the sensor (hall effect or magnetoresistive), replaces the points.
I don't think you have one. Isn't your SC using a DIS not a distributor?
RwP
Old 02-23-2012, 12:35 PM
SC Newbie
I'm not sure. Just purchased my SC. Still learning it. What's DIS???
Old 02-23-2012, 12:52 PM
r1dd1ck913 r1dd1ck913 is offline
SC Owner
It's stands for distributorless ignition system.
  #5
Old 02-23-2012, 05:24 PM
Hiram K Hiram K is offline
SC Newbie
Just my .02 cents worth; if you plan on keeping the SC, the first thing you need to do is purchase the proper shop manual for the car. Unless you have deep pockets you most certainly will need to "understand" the workings of your car. I have had 2 of these and they are not for the weak of heart. The ignition system is easy, really. Wait till you start on the brakes. Have fun.
  #6
Old 02-23-2012, 08:35 PM
the-big-e's Avatar
the-big-e the-big-e is offline
You can't fix stupid
SCCoA Member #: 2502
Brakes are not that hard, once you understand how they work.....
__________________
Flying is the 2nd greatest thrill known to man. Landing is the first !!!!
Every day, I set a personal record for consecutive days I have remained alive!
If you cut a crumb in half, you don't get two half crumbs, you get two crumbs
Doesn't this violate some law of physics?
  #7
Old 02-24-2012, 12:11 PM
S_Mazza's Avatar
S_Mazza S_Mazza is offline
SCCoA Member #: 2821
Thanks
It receives signals from the camshaft and crankshaft position sensors and outputs the primary ignition pulse in the proper sequence. That pulse goes into the coil pack, where it is converted to the high-voltage pulse that reaches the spark plugs.
In the early model SCs (1989-1993), the ignition module is pretty important. It's a lot more complex than the old ignition modules (TFI modules) that were on distributor-equipped Ford cars.
If the distributorless ignition module goes bad, the car will misfire badly.
__________________
God bless!!!
1990 SC auto ... red outside, gray cloth inside ... ~180,000 miles (and climbing) ... driven daily!
  #8
Old 02-24-2012, 06:44 PM
bowez bowez is offline
Misfire? You'll be lucky if it runs at all.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
BWD - Ignition Control Module dakotaflstf Parts for Sale 0 05-28-2010 12:06 PM
Wanted Integrated Relay Control Module kenkay Want to Buy 11 06-28-2007 09:43 AM
Venom 400 control module... JOE91SC Technical Forum 6 04-25-2006 03:07 PM
relay control module ReDevilXR7 Technical Forum 2 08-29-2002 09:21 PM
