Go Back   Super Coupe Club of America Forums > SCCoA Chapter Forums > Super Coupe Club of Northern California
User Name
Password
Reply
Old 04-04-2012, 06:05 PM
90scmxdream 90scmxdream is offline
SC Newbie
Unhappy smog check
Hi I took the sc today for the smog chek and it fail emission ,he said the cats are not good, and he gave me a prize. for cats $620, labor $180. is not that to expensive ?? do you know if there is something less expensive ? please help
jose.:
Old 04-04-2012, 06:48 PM
Ddubb's Avatar
Ddubb Ddubb is offline
blowin brains
SCCoA Member #: 2822
What are the numbers ? What did you fail on ? NOX too high ? HC's ??
- Dan
Old 04-04-2012, 07:40 PM
SC Newbie
Dan it fail nox the numbers are max 530 meas 945.
Old 04-04-2012, 07:57 PM
Ddubb's Avatar
blowin brains
I dont think new Cats will fix your problem either. Maybe they will lower the numbers down a little but not a whole lot.
Nox = Nitrogen and Oxygen combined at high temperatures, too much Oxygen in your system.
NOX too high is from too high of temperatures in the combusion chamber - or your engine is running too hot alltogether.
Usually the EGR lowers the temp by adding extra air ( burned air has less oxygen in it, the hot air displaces the oxygen in your engine ) but your car does not have EGR.
Timing could affect this, but timing is non-adjustable on these engines also.
You could also have a vacuum leak making the engine run too lean. I would check for vacuum leaks first, then make sure your o2 sensor, MAF sensor are working good, and Check your Fuel pressure also, too low of fuel pressure will make it run lean also.
- Dan
  #5
Old 04-05-2012, 03:38 PM
91BLOWNBIRD 91BLOWNBIRD is offline
SC FEVER
SCCoA Member #: 2924
- Dan
I will 2nd and 3rd Dan's comment...check for vac leaks, if all good then make sure you aren't running lean, then if all good replace CATS...
and yes that is far too much $ for CA legal CATS to be installed...I would say $400 out the door $150ea CAT and $100 labor
  #6
Old 04-05-2012, 05:41 PM
SC Newbie
hmmmm .Dan remember i have I manual switch to turn the fan on well yesterday when I took the car to smog I forget to turn it on and by the time ,
I did the car was already to hot
the technician told me the car fail mainly because the car was running hot.
jose
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Passive Restraint Pearl Red XR7 Technical Forum 27 06-16-2009 06:36 PM
Question on the tranny check balls.. v8killr Technical Forum 1 03-30-2005 11:02 AM
RPM tach and check engine light nick2003 Super Coupe Club of Ontario 15 03-10-2005 01:28 AM
Check this out....Carlisleforums.com.... lube70 Non Technical Forum 1 10-04-2004 09:38 PM
Check Engine Light 455Poncho Technical Forum 2 08-05-2002 01:55 PM
