User Name
Password
Reply
Old 06-06-2012, 03:04 PM
95_XR7 95_XR7 is offline
SC Newbie
SCCoA Member #: 3332
Send a message via MSN to 95_XR7
HRPT - 5 June. My '95 on the dyno.
Mods are listed on my member page.
To sum it up:
340LPH fuel pump and 60lbs injectors. Adj fuel pressure regulator
Magnuson S-Port, Inlet, DIC with fan. Intake side is all upgraded.
Exhaust is done.
94.81 and 11% humidity
Run 1:
HP: 263.45
TQ: 323
Run 2:
HP: 261.30
TQ: 328.73
I wish it had been higher.
-Corey
Old 06-06-2012, 03:43 PM
Ken Seegers Ken Seegers is offline
No blue SC, No teal SC!
SCCoA Member #: 193
Corey,
It looks like the car is running rich. I take it you have a chip or moats...right? Lean it out a bit and it should run better, but still not bad of a run.
Ken
__________________
1992 Thunderbird SC
13.322 @ 102.81
1993 Thunderbird SC 5spd..white
2002 F350 SD Diesel (SC tow vehicle)
Old 06-06-2012, 03:44 PM
90coug's Avatar
90coug 90coug is offline
Huntin' for Stoich
SCCoA Member #: 2682
Send a message via MSN to 90coug
Hey, that's not too bad. You have as 260HP bird now.
Here are my suggestions.
PP Heads
Rowdy CAM
Front Mount Intercooler
I have a double intercooler like you have and while it provides additional room for the air to travel thru it heats soaks just as bad as the OEM. Once those ACTS get high enough it'll start retarding the timing.
Plus you can OD the piss out of your supercharger once you get a better cooling solution.
I've also been told that running e-85 can net some serious increases but might require at least 80# injectors. You could do the 60# but the duty cycle might not be desirable.
How much timing are you running?
__________________
'95 SC
Garage
Old 06-06-2012, 07:50 PM
SC Newbie
Quote:
Originally Posted by Ken Seegers View Post
Corey,
Ken
Currently using QH and BE. Unfortunately, don't now the software well enough to remotely tune it. I also wasn't putting too much into the AF for those runs. It's odd but when I first got the chip and tune from Dalke, I had my WB02 hooked up and AF ratio was pretty close to what was being commanded. Whenever I get back stateside I'll have to look into it more.
Off the top of my head, I don't have a clue about timing. I could try and find some past datalogs (1yr ago ish) and see what it was then. Not much has changed. And I agree about mods. The FMIC is currently in the works, and I was about to send an email off to see about heads, cam, and ETA on new supercharger.
-Corey
  #5
Old 06-06-2012, 09:19 PM
shoalcracker shoalcracker is offline
SCCoA Member #: 3770
I can't comment on your data.
I think some of your upgrades allow you to have some options.
Bigger valves, port and polish and a more aggressive cam may net 50 hp.
Talk to your local builder and stop by DD on this forum.
He's very famiilar with all staged builds.
Paul
  #6
Old 06-06-2012, 10:55 PM
XxSlowpokexX's Avatar
XxSlowpokexX XxSlowpokexX is offline
SCCoA Member #: 2007
Send a message via AIM to XxSlowpokexX
Stock heads and cam....Not bad at all for your combo in my opinion. Better IC and or meth will get you more with stock heads and cam.
__________________
1994 5 speed-Who needs a MAF anyways!
0 RWHP--0RWT
0 @ 0mph
Quote:
Originally Posted by ricardoa1 View Post
  #7
Old 06-08-2012, 08:59 AM
SC Newbie
Here's a video if anyone's interested.
You can tell it was pretty windy out, so I apologize.
95 SC Dyno
-Corey
  #8
Old 06-08-2012, 09:06 AM
XR7 Dave's Avatar
XR7 Dave XR7 Dave is online now
ask questions-get beat up
SCCoA Member #: 1508
You can see clearly in the 2nd pull how quickly timing was being pulled out after 4500rpm. It's just not getting enough cooling of the air charge which is common. Lowering boost through reduced restriction and increasing intercooling is essential to make any more power than that. It may be disappointing, but those are actually very good #'s.
__________________
Email me here.
  #9
Old 06-08-2012, 09:28 AM
SC Newbie
Quote:
Appreciate the info David. One thing I'm currently working on is figuring out what the exact route is that I want to take in regards to the IC. Whether it be a custom FMIC, or the MP FMIC. Price is a huge advantage to doing it custom, however, if I go that route I'm gonna experiment with the core to see what the best combination is for pressure drop, cooling capacity, etc as per a few of Fraser's info filled threads.
Heads and a cam to help the engine breathe is another route. Which you'll have an email about as soon as my gmail quits acting up.
Think it's possible to get 300 without doing heads and cam?
-Corey
  #10
Old 06-08-2012, 09:47 AM
XR7 Dave's Avatar
-Corey
Going custom is an advantage if you don't care what it looks like. If you want the chrome tube look then the MPFMIC is the only way to go. Also, on the 95 due to air bag sensors and some other things in the front bumper area, a custom FMIC is not going to be as easy as you might think. There just isn't a lot of room there.
As for IC cores and airflow, it's mostly about size. There isn't much if any difference in flow between the MP and the Ebay versions. It's a lot more about fitment than anything else.
You won't make 300rwhp without heads/cam. For someone like me who does all their own fab work and tuning as well, it might be possible. But the fact that I haven't made a serious effort at it should give you a clue as to the practicality of actually succeeding. I've seen a lot of people get close, but never with an auto, and it would always have been a lot easier on everything (including your wallet) with heads/cam in the mix.
__________________
Email me here.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
2012 HRPT - Madison, IL (near St. Louis) (Stop #4) June 5 Kurt K SCCoA Events 9 06-06-2012 04:49 AM
2012 HRPT - Detroit (Stop #1) June 1&2 Kurt K SCCoA Events 1 06-03-2012 06:31 AM
2012 HRPT - Arlington, TX (Stop #7) June 8&9 Kurt K SCCoA Events 1 05-17-2012 08:35 AM
2012 HRPT - Champaign, IL (Stop #3) June 4 Kurt K SCCoA Events 2 05-15-2012 10:28 AM
