Codes codes codes
It lives!!! The Haynes manual was not wrong on the firing oder. They must have fixed it. It also had two broken spark plugs that was causing my problems.
Now it runs and is an awsome motor! Here are my final problems, I hope: Check engine light comes on every now and then while driving. Stays on for a minute then goes out. Codes: 173, 177, 179, 188 Any suggestions? Also it idles so low that it wants to die and does most of the time. I hade to put a little piece of folded tape under the throttle assembly just to keep the idle up to where it won't die. Maybe bad Idle Air Controller? Thanks for any help. Last edited by MtDewd; 11-09-2002 at 11:25 PM.. |
www.batauto.com.....you can get your code explanations there.
z
__________________
90s/c,MP blower & plenum,CMRE Stg 1 heads/cam,3/4 raised top,85mm MP TB,60# injectors,87mm C&L MAFS,MP CAI,Kooks mids w/3" mid pipe & Magnaflows, AOD w/trans-go,trans-cooler,373's, SCT Chip tuned by Ed Clark,10% SC pulley,5% JS pulley,ASP u/d pullies,MP fmic,Griffin rad,AADCO 1 3/8" swaybars,clear corners,Eibach prokit,MRK VIII front spindles/brakes,255/45's front...275/45's rear on 17" Dante Bullets,SCCoA#1656...and one badass MRK VIII |
codes
All the codes are explained in the Haynes manual.
Looks like your o2 sensors are reading; 173=rich right side 177=rich left side 179=rich right side 188=rich left side |
codes
173= hego [ho2s]sensor fault rich 177= hego [ho2s] sensor/fault always rich 179= fuel system at lean adaptive limit at partial throtle / system rich 188 = fuel system at lean adaptive limit at throttle / system rich
| Thread Tools | |
