Looking for SC engine block
Have a 90 t-bird with a rod through the side of the block. Also anyone recommend any good engine rebilders in the Kitchener/Guelph area?
rooster77,
Is it an SC that you threw the rod in? If not, then there's no reason you couldn't just use a plain-jane 3.8L NA block. You'll find this to be a much cheaper solution, and these blocks are much more readily available. Cheers, Sean |
yup, it is a super coupe, so I would like to keep the super charger and all working.
hey your in my area of work....
call Tom Morana |
#5
Who is Tom Morana, how do I contact him...he an engine rebuilder?
#6
Check this out:
www.moranav6racing.com Tom is located in Toronto. He specializes in building quality Ford V6's. He may even be able to supply you with a core. Best regards, Sean Last edited by SeanMatteson; 05-04-2003 at 01:12 AM.. |
| Thread Tools | |
