#61
I find this very interresting and want to see some results before I rebuild my motor very soon so as I may do the same if it seems worth it!
__________________
Greg Coleman 89 XR7 SC Mississauga Ontario Canada 333 RWHP 417.0 RWTQ & Nickey's hot rod 94SC |
#62
Quote:
#63
That makes some sence but its been a while since I have done a test like that (at least 5 years) and I cant remember a time there was a problem that I even noticed a difference over like 2-3%.
BKB is your WHOLE triangle still in there? |
#64
Theres a fix for that fuel rail pressure problem in the works right now Fella's. No details yet except to say it involves a completely new fuel rail system.
More to come later. ![]() |
#65
Ohhhhhhhhhh thats just not right. Tasty little tidbits of information and then...the big "More to come later". You really know how to keep us beggin fer more...
Chris |
#66
And what mike is doing is really nice to.You will just freak out.LATER
#67
Yes i built a new triangle out of sheet aluminum and welded it in there. You need something to support the intake.
#68
So...we should not cut it out? Im confused. Why does it need support? Why cant I make a small support out of like a bolt or something of that nature? That would give me tons more volume and give me support. Im not trying to be a smart@$$ but half say it wont work and half say it will. This is a relatively big issue. The way I see it is like telling me I dont need tires and the car will drive fine.
Chris |
#69
All i said is it need support, any kind of support. Do the math and figure out how much pressure is pushing on the top of the intake at 15psi and you tell me why it needs support. The intake is very thin and about the worst quality aluminum i have ever seen. My idea was to weld in a 1'' rod in the middle for support but like i said the book i read said it is helpfull to have a deflector in the intake to direct air flow so i kept the triangle. I might remove the triangle after i modify the rear of the intake to enlarge the opening.
#70
Think about this for a moment your radiator tubes oporate at 16 psi when the coolant reach's full temp. Those tubes at the most are only .020" wall thickness. why would 3/16"-1/4" thick Aluminum need bracing to hold up to 15 psi?
#71
my inverted has no support .
#72
Manny your blower supports you intake..:O)
The cast aluminum Ford uses is junk..However I still think teh triangle is to divert airflow...Now...We need to speak to whomever designed this intake and end it once and for all:O)
__________________
#73
well it is weak i can break it out with a small hammer if i wanted
i will take a picture of some scrapes from inverted its real thin and full of air holes amazing they dont leak |
#74
You will get just as much performance gain from bolting on a weedeater
on the end of the cold air pipe as your going to get from removeing that triangle. Manny didn't you replace the top of the manifold with about 1/2 inch aluminum. What you have done is a lot stronger than a stock setup. RANDY PS a 2 horse weedeater would just **** an get. |
#75
sheeesh it 1/4 inch my secret!!lol
| Thread Tools | |
