User Name
Password
Reply
Old 06-17-2004, 10:35 AM
94SCblack5speed 94SCblack5speed is offline
SC Newbie
Major loss of power under boost
Every time i step on the gas pedal and give the car more than 3-4 lbs of boost i feel a shaking sensation and alot of vibration. I have to let off the gas just to get the car to accelerate it seems. Car has about 158k on it any suggestions would be appreciated. I just replaced plugs/wires and its still having the same problem.
Old 06-17-2004, 11:35 AM
David Neibert's Avatar
David Neibert David Neibert is online now
Still loves the Cobra Rs
SCCoA Member #: 858
Sounds like a fuel delivery problem. The fuel filter, fuel pressure regulator (not increasing pressure) or the fuel pump could cause those problems.
Start by looking at the regulator and make sure the vacuum hose didn't fall off. Then buy or borrow a test gauge...with vac line off the regulator you should be getting between 38 and 40 psi on the rail. With vac line attached it should show about 35 psi at idle and pressure should increase with manifold pressure.
Poke the throttle hard enough to get into boost and confirm that fuel pressure is increasing pound for pound with boost. 10 pounds of boost should result in 50 pounds of fuel pressure. With a weak pump or clogged filter you will not be able to maintain flow and pressure when in boost and the fuel pressure reading will begin to fall instead of raise.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
Old 06-17-2004, 12:18 PM
SC UL8R1990's Avatar
SC UL8R1990 SC UL8R1990 is offline
SC Newbie
SCCoA Member #: 2227
Send a message via AIM to SC UL8R1990 Send a message via Yahoo to SC UL8R1990
also check the clamps on your air intake hose. My intake tube fell off the throttle body and had the same exact symptom as you.
Old 06-17-2004, 08:26 PM
Deep6 Deep6 is offline
SC Newbie
SCCoA Member #: 1409
I had a similar problem to this a couple weeks ago...
It wasn't fuel or intake or spark probs.
Instead it was a clogged exhaust. Hopefully that isnt your problem, but it could be partially clogged up. I had a severe loss of power in my 95-5spd. Hollowed the cats out and it solved the prob.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Boost leaks, what they do and how to deal with it Vernon Technical Forum 27 04-16-2013 12:19 AM
conventional plugs, superchargers and dyno tune tbird91sc Technical Forum 11 07-02-2003 03:38 PM
Loss of power, low boost pressure MTTod Technical Forum 3 06-09-2003 11:53 PM
Boost leaks, what they do and how to deal with it Vernon FAQ Forum 0 03-05-2003 04:03 AM
