User Name
Password
Reply
Old 06-22-2004, 04:16 PM
dms825 dms825 is offline
SC Newbie
Rear stabilizer bar end links
Are there supposed to be bushings in the top part of the rear stabilizer bar end links? The rest of the bushings in the rear look fine, and the bottom bushings on the rear end links look good, but there's nothing in the top of either end link - just bare metal hitting bare metal.
Old 06-22-2004, 05:04 PM
gldiii's Avatar
gldiii gldiii is offline
SC Newbie
SCCoA Member #: 478
Same bushings on top as on bottom!
Old 06-22-2004, 08:41 PM
fast Ed's Avatar
fast Ed fast Ed is offline
now with vintage Bird!
SCCoA Member #: 724
Send a message via Yahoo to fast Ed
The factory rear stab. links have an "eye" in the top end, should be a round bushing in there. This attaches to the adapter bracket that is on the ends of the rear stab. bar. You can go with a pair of generic aftermarket end links that just use a stud and two bushings on each end, if you remove those adapter brackets.
cheers,
Ed N.
__________________
former 10-year owner, 95 SC 5-speed / 89 Mustang GT / 66 Thunderbird Town Hardtop 390-4V / 94 Thunderbird LX 4.6
Old 06-23-2004, 11:43 AM
93BLKSC's Avatar
93BLKSC 93BLKSC is offline
SC Newbie
OEM vs. aftermarket
Quote:
I don't understand why more people haven't done exactly this. The ADDCO or Energy Suspension end links are MUCH stronger than the whimpy OEM end links!
But for people who just gotta have an "original-ish" part, I think that mn12performance sells repo OEM end links with poly bushings.
68COUGAR
  #5
Old 06-23-2004, 03:58 PM
Joisey Jim Joisey Jim is offline
SC Newbie
SCCoA Member #: 362
Like everything else there are pros & cons. If you have the stock bar you can only use the slim (3/8" bolt I believe) Energy Suspension links and they tend to bend. I guess that's why the stock bars have swivel joints in them (front & back). I have the 1.1/8" Addco bar on the rear with their 5/8" bolted link & lower springs and, that seem to work ok. I've heard other people have had better success just cutting the stock links shorter & welding them back together. Then just replacing the stock bushings for urethane ones.
What I'd like to know is what is best for a lowered front. I still have the stock bar & links, and Addco won't answer my e-mail about supplying me shorter links for the front. I wonder what they supply, if anything, for the fatter front bars they sell ??
  #6
Old 06-24-2004, 06:28 AM
93BLKSC's Avatar
SC Newbie
Re: 3/8" hardware
Quote:
The answer to this problem is only a drill bit away!
68COUGAR
  #7
Old 06-24-2004, 07:05 AM
Rich Thomson Rich Thomson is offline
SC Newbie
Exclamation
MN12 Performance sells a complete polyurethane kit for the rear sway bar and it includes end links. All SC had the 3/4" endlinks. v6 and v8 used 5/8" endlinks.
Rear Sway Bar Kit
  #8
Old 11-08-2004, 06:32 AM
seawalkersee's Avatar
seawalkersee seawalkersee is offline
still likes Nick...
SCCoA Member #: 2678
I have done a search and can not find the sway bar end links parts for the lowered cars...Anyone?
Chris
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
rear stabilizer bar help jnobles Technical Forum 2 05-12-2004 09:59 AM
Since May 1st.... 89SCK@t Non Technical Forum 0 12-03-2003 01:51 PM
need info on rear sway bar bushings and end links j rick kirby Technical Forum 2 09-04-2003 10:41 AM
Front sway bar end links supercoupe92FL Technical Forum 5 01-13-2003 06:28 PM
