Go Back   Super Coupe Club of America Forums > SCCoA Chapter Forums > Super Coupe Club of Ontario
User Name
Password
Reply
Old 07-19-2004, 05:04 PM
T1Bird's Avatar
T1Bird T1Bird is offline
Again, another Rad post.
Alright, Ive tried to deal with this one myself but its only lead me in about 5 different directions, my problem is last summer i had my rad re-cored, the dumbazz's didnt replace the rad drain plug, or fitting in the tank, on my rad the actual fitting is round, no hex head on it to take it right out of the tank.
I went to crappy tire and bought 2 replacement fittings, but of course i cant remove the female end of the fitting out of the rad, because well there is just no possible way, so in attempt to use the male end in the my existing fitting the wing nut on the ~~~ has busted twice, and both are pooched..
what have you guys found for a replacement? or is it my basterd of a tank the only one like this?? let me know
Old 07-19-2004, 06:19 PM
Jason Wild's Avatar
Jason Wild Jason Wild is offline
Send a message via ICQ to Jason Wild Send a message via MSN to Jason Wild
Well if it's like mine you will have a hard time geting the niple out of the end tank since it's welded in.
Old 07-19-2004, 06:41 PM
Paul93SC Paul93SC is offline
Bruce...
I don't think you'll be able to fix that. I've tried in the past on other rads and had zero luck. Just leave it alone (as long as it's not leaking) and disconnect the lower rad hose in order to drain the system.
Old 07-19-2004, 06:44 PM
T1Bird's Avatar
well it wasnt leaking but stupid me, if i see it needs to be fixed i fix it...looks like ill just take it to work and tig it shut completely, I never even use it to begin with, only use the lower rad hose, I dont have time to wait for over 3 liters of anti freeze to drain out of a 1/8 NPT hole
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Any Intrest in Custom Aluminum Rads? MIKE 38sc Technical Forum 130 07-10-2004 02:40 AM
Rad Issues JimGravelle Super Coupe Club of Ontario 26 01-20-2004 03:34 PM
rad cap ???? stephens89sc Technical Forum 1 10-22-2003 12:58 PM
Custom radiators :Update: MIKE 38sc Technical Forum 32 10-17-2003 10:56 AM
Rad and IC bracket V6Sprout Super Coupe Club of Ontario 5 04-11-2003 06:19 PM
