Head gaskets?
my sc was running a little hot lately and i figured it was the thermostat, so i ended up getting a coolant system check just to be safe, and i find out that its almost certain that i have a blown head gasket because of an internal leak. so im gonna get a compression test and find out forsure. but my question was , has anybody had there heads done? and how much am i looking at? |
Re: Head gaskets?
If it's done at a dealer your almost certain to pay anywhere from $1000-$1500. Personally if I had access to another vehicle for a week or two I would do it myself and save myself the $900 labor bill. Or maybe see if maybe Raj or Len could help you out. Hope its not the head gaskets! Good Luck! |
Re: Head gaskets?
re % re head gaskets $500.00 Head gasket kit $273.00 Head bolt sets $38.50ea 77.00 Platinum Spark plugs $8.55ea 51.30 Plug Wire Set $88.95 (i think thats bull cause i saw stock ford wires on my car as far as i could tell that ~~~~in loser of a mechanic bastard!) thermostat $8.50 then coolant, oil filter oil and hose clampse $40.00 TOTAL $1179.05 and i think i was payin a shop rate of bout 54 or 52 bells an hour. |
head gaskets
and don't forget getting the heads done . pressure checked 5 angel grind springs and plaining . this is a real fun job .. then you might be looking at o2 sensors. if i can be of help i am around the board. where are you located. |
#5
head gaskets
its alright i apreciate the offer but i got it all lined up thanx anywayz! |
| Thread Tools | |
