Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 02-03-2005, 09:03 PM
danekejt's Avatar
danekejt danekejt is offline
charging battery
bought a battery charger from harbor freight tonight. this is the one that i bought http://www.harborfreight.com/cpi/cta...emnumber=47447. hooked it up to the black bird to charge the battery. i noticed as its charging it goes from charging to full charge. bounces back and forth between both while charging.
i disconnected the charger. reconnected everything making sure that everything was connected properly. then it proceeds to bounce back and forth from charging at 100% to fully charged then back again to charging.
is this normal. i was expecting it to do a steady charge and then the green light coming on when the battery is fully charged.
thanks for any and all answers.
Old 02-03-2005, 10:52 PM
J.D.'s Avatar
J.D. J.D. is offline
This is what it says in the description for your charger: Charger shuts off output when battery is fully charged - monitors battery, and automatically turns back on if needed.
This leads me to conclude that it is either defective or there is a large current draw on the battery, causing it to keep turning back on. Did you buy the charger because your battery was running down overnight?
My trickle charger does not keep cycling between "charging" to "full charge".
To verify if your charger is bad, disconnect the battery from your car and then see if it bounces back and forth.
Old 02-03-2005, 11:51 PM
danekejt's Avatar
yeah i bought the it because i havent started the car quite awhile. the battery was not strong enough to start the car. i did notice that after awhile that it stayed in charging mode. just checked now and it is switching back and forth again.
thanks for the suggestions i will try that and let you know how it went.
Old 02-04-2005, 12:02 AM
danekejt's Avatar
well that seems to have done the trick. just checked the car. took the charger off and car turned over as it should
it also has something in the manual that says that the charger doesnt force the power to the battery, the battery takes the charger when wants it. maybe that is what it was doing.
thanks for the reply and the suggestions..
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
"Pregnant" battery J.D. Technical Forum 25 11-22-2004 02:21 AM
battery charging problems HSKR Technical Forum 9 11-04-2004 12:27 PM
Battery light problem CHIRPIN'INTO2nd Technical Forum 4 08-31-2004 02:00 PM
Droping 20lbs WITHOUT gutting interior? (Pics) Deep6 Technical Forum 7 08-22-2003 03:03 PM
Need help charging battery for altanator fix 1990_Tbird_SC Technical Forum 4 02-15-2003 03:54 AM
