User Name
Password
Reply
Old 02-19-2005, 02:10 PM
AlanEdwards AlanEdwards is offline
Motorcraft part number confusion
I found some double platinum Motorcraft plugs at Autozone for $25.92 out the door. My confusion is that the correct plug is Motorcraft part number AWSF34PP, but Autozone says they have Motorcraft part number AGSF34PP. Is there a difference between the "W" and the "G" in the Motorcraft part number? Thanks for any help.
Alan
Old 02-19-2005, 02:20 PM
TC88 TC88 is offline
plugs
i was told that the only replacement for the awsf34pp was agsf34fm the stock number is 6104. thats all i know, just thought i would throw that out there.
Old 02-19-2005, 03:52 PM
blue94sc's Avatar
blue94sc blue94sc is offline
Hey Alan. Nice 94 Sc!
There was a recent article with more on plug numbers...
Go here.
Spark Plug Question
I believe that they will work fine.
Bill
Old 02-19-2005, 07:32 PM
Go here.
Spark Plug Question
Bill
Blue94SC and TC88, thanks for the spark plug info, and thanks for the compliment Blue. I wanted a white SC since '89 and found this pearl white SC a few months ago on eBay and jumped on it.
Another question though: I have found both Motorcraft plugs, the AWSF34PP as well as its replacement, the AGSF34FM. I've been recommended to go with the original, the PP. The biggest difference is the "fine wire" to the electrode in the FM. Is there anyone that knows which I should go with? Thanks for your help.
  #5
Old 02-19-2005, 07:54 PM
Michael Mattix Michael Mattix is offline
I have a 95 with the G's. They run fine.
  #6
Old 02-20-2005, 12:11 PM
blue94sc's Avatar
I have seen threads where people have had problems with the fine wire plugs.
There has been no real issue with the PP plugs as far as I remember.
On the Motorcraft web site they list the AWSF34PP as double platinum plugs.
They list the AGSF34FM as an alternative platinum plug.
Not sure if it is double platinum or not.
Here's another thread where XR7Dave lists some of the pulgs used on the SC's.
Spark Plugs
Bill
  #7
Old 02-21-2005, 03:07 AM
kendall221 kendall221 is offline
It appears that the AWSF34PP plugs are becoming harder and harder to find. So far, I've struck out on getting them at RockAuto and AutoPartsGiant.com. Both places had them listed in their online catalog, but when I tried to order them, they didn't have them. RockAuto wanted to replace them with AGSF34FM plugs, which is listed as the alternate Motorcraft plugs. They are only single platinum.
  #8
Old 02-21-2005, 11:43 AM
Maybe just having one side with platinum is all that is needed? I am assuming that "single platinum" means that only one side of the spark plug is platinum tipped. I would also assume that it is the electrode side. I thought the platinum was on the plugs just to make them last longer. Now that I know how to change them within three hours from the top (I like to take my time), I am not worried about putting in double platinum vs single platinum.
  #9
Old 02-21-2005, 01:55 PM
I've found them!!!
I found some Motorcraft AWSF34PP double platinum plugs. If anyone's interested, I can get them to you for $10 a piece, shipping included. Send me an IM if you are interested.
  #10
Old 02-21-2005, 03:24 PM
Splicer Splicer is offline
Watch out with Single Platinum! They will only be correct for one bank. The other side fires in reverse, therefore the Doubles, so you can't mess up.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Part# for motorcraft plug wires... CaifanSC Non Technical Forum 6 01-09-2005 05:09 PM
Help! Need MAP/BAP Sensor Part Number Check! BlackSC Technical Forum 1 05-02-2004 02:27 AM
Bilstein part number fastsc92 Technical Forum 2 02-23-2004 10:31 AM
CD Slave Part Number Interchangeability carlislesc Technical Forum 0 02-13-2004 04:22 AM
Need part number for TV cable brass bushing and cotter pin Scott Long Technical Forum 9 07-18-2002 12:43 AM
