Custom Built Front Drag Coil Overs
I have been working on getting these built for some time now. These are custom built QA1 Pro Drag Shocks for MN12s. I just got them yesterday, and will install them in the next couple of days. These are Prototype now, but as soon as tested and any changes needed, they will be available. They were built by a QA1 dealer, not the QA1 shop it self. I will update as I progress. These are 90/10, set up as fixed Compression, and fully adjustable Damping, (extension). These alone take off about 20 lbs from the front.
![]() Lower part: ![]() These are still Prototype, and no firm price has been set. They mount to the lower control arm the same as the stock ones do, and mount to the stock top piece, that has the 3 studs on it, as the factory ones do. |
Hey Bruce! Nice job!!!!!!!
You need to contact Randy because I think he was wanting some of those. Put this thread in the new parts section. I think you might have a hit on your hands. ![]() |
I would be interested in this setup if you could get them in a 70/30 setting for the street strip guys and there would be a bigger demand as well. It would be great to get QA1 to do a shock shock for the rear too.
Zack |
These are done as a prototype, and when it is determined that they are correct, and if there is decent interest shown, they will be made available to your specs. Once the fronts are done, we can start on the rears. My Bird weighs less than 3200 lbs, so when done, will have them determine what is needed for the different weights, strip only and street/strip use.
#5
A few pictures taken today during the install.
The coil over with the stock top piece installed, ready to go. ![]() Mounted up to the shock tower from the bottom ![]() View from the top ![]() View of the bottom mount, 12 position adjuster knob and heigth adjustment ring ![]() Over all view installed ![]() I have a few thing to get changed, then they should be ready to make them as needed. Example: Will advise them to do these with the adjuster knob to the rear. This will protect it, and allow easy adjustment by just turning the wheel and reaching in. Ideal for between round changes at the strip. A few other minor things. |
#6
With the range of available adjustment, with a fixed compression and adjustable rebound, it would seem obvious that the 90/10 would apply to a full soft setting. Full firm would be something else 50/50 perhaps?? What is the range?
__________________
Email me here. |
#7
PLEASE!! keep us posted on these shocks. Those are what I have been dreaming of. With a manual steering and Mustang hubs with skinny tires real race car. Thats what Iam talking about. Thanks for you work on these!
#8
Dave they make road racing shox as well in that form....And spring rates so you can go either way.
__________________
#9
Dave: Bo idea on what they will go from-Too. I did the test install today, and need to do a few other things before they go on for good. Also the springs I am using are only to get a eough idea on the fir. They will come back off, and go over to my buddys shop as soon as he is back from Daytona. He has a full race shop, and I will put these on his shock dyno, and get data. I need to get it 4 corner weighed also, then will decide on what springs it will get for the strip, most likely in the 175-200 lb range. They can valve these any way you want. I told him when in the lowest setting, I wanted to be able to pull the tops out with one hand, and wanted the compression stiff enough that if the car was off the ground and set down, it would take 3-4 seconds to settle the shocks
Ill see on the dyno how close he got. Oh, and once all the little details are worked out, they will make these up for any type drivivg, and adjustable or not. I will keep everyone up to date. I hope to have this completed, and ready for our local strip to reopen Mid March. |
#10
392bird
Is it possible to get the front coilovers NOW.I have been getting parts together to finish my 4130 k-member.I plan to swap my k-members again in the next couple weeks.If I get all the parts made & assembeled on my new K-Member.Road race shock valveing is the shock set-up I like to have. Maybe you can help me with these's parts .I am wanting to machine or buy,Aluminum hubs,and aluminum brake carrires with bolt-on disc brake rotors. I hope to take close to 100 pounds off the front. With the use of a 4130 AJE K-Member with my lower control arm, plus aluminum hubs,brake carrier,aluminum adj coil over shocks. And some left over H.D. parts. I would be interrested in buying a front pair NOW.If you want to sell any. I am interrested in rears also. Thanks Randy Last edited by Randy N Connie; 02-22-2005 at 11:29 AM.. |
#11
I will be out of town today, and need to get a couple of small things sorted out tomorrow on these. I hope to have everything worked out, and final install next week. If so, will pass on all information to the shop and here.
Randy, you sure those pieces for the HD are not oil soaked? ) JKYou need to get Pet Hill to be your partner, then you would be sure to lead the pack ![]() Bruce |
#12
Pete & Jackie drive GM type stuff
Randy ![]() |
#13
I commented over on TCCoA about this, and I will comment here. I am very concerned about the manner in which these coilovers load the stock upper mount. You are applying a large force to an area that wasn't originally designed to withstand that much load. You are basically point loading the center of that mount. Originally the outside of that mount was designed to carry the load transferred via the springs, but now you are changing that drastically. I think go to with this you need a new upper mount as well, whether it be via a rod end type connection or a bushing type. By the way, I would guess those were built using C5 Corvette rear shock parts right?
John |
#14
John there is no design change for the front of mn12 birds.
They all ready have coil over shocks on the front. But they are not aluminum and adjustable.And no-one makes a adjustable aluminum shock with the poper bottom mounting. Some work may be needed for rear adjustable coil over shock installation. Randy Last edited by Randy N Connie; 02-22-2005 at 12:06 PM.. |
#15
Yes...there is a MAJOR design change...In the stock configuration, a 5" spring sits in the spring seat molded into the upper mount. This seat is backed by a metal plate in both the mount and the shock tower. That is the load path to the chassis. In this design however, the load path is through the center of the mount where the stock shock rod passes through normally. This is a MAJOR change from how that mount was designed to be used. There is no steel plates there to reinforce it. You are changine from a very distributed load to a very concentrated load. This will eventually lead to a failure in the upper mount.
John |
| Thread Tools | |
| Continued ABS woes (and others) | gregs90sc | Super Coupe Club of Ontario | 22 | 07-11-2007 08:35 AM |
| My New Rims on, What do you think ? | SuperCoupeSC91 | Non Technical Forum | 47 | 03-08-2004 05:04 PM |
| front mount intercoolers custom | stephens89sc | Technical Forum | 29 | 11-13-2003 05:05 AM |
| Subframe Assembly | rhanumaiah | Technical Forum | 6 | 06-12-2003 03:24 PM |
| Front Mount IC w/ Custom Raised Top | BlueThunder90 | Technical Forum | 4 | 09-10-2002 10:41 AM |
