egr tubes
I need the tubes for the EGR valve that go from the exhsut manifold to the EGR valve. Got a constant check engine light because I had to remove them when I did my head gaskets. I couldn't get the tubes to come loose from the manifolds so cut them off. Thought I coudl get the car to run okay without the EGR hooked up. Now I just want to get rid of this damn check engine light and from what I've read, having the EGR hooked up should help it run better.
I tkink you can get them at the dealership. They are so brittle i think it will be hard to find used ones.
| Thread Tools | |
| EGR Deletion revisited.. Please help... | phils89sc | Technical Forum | 5 | 07-10-2003 01:31 AM |
| egr bs.. | DrFishbone | Technical Forum | 9 | 06-09-2003 09:53 PM |
| Changed bad EGR valve, broke my EGR tube!!!! | phils89sc | Technical Forum | 6 | 05-06-2003 11:51 PM |
| What year Super Coupes had the EGR valve? | blkthndr | FAQ Forum | 0 | 10-28-2002 07:14 PM |
