Changing out seat belts from later sc
Can I swap out the junk automatic seat belts in my 93 for seat belts out of a 94, 95? Would it be just as easy to find a stock thuderbird in the junk yard and take out the side panels and belt system? Im sure this has ben brought up before somewhere but I havent had time to research it.
Ken |
You can DO IT!
I just did what you're talking of doing in my 93. Its not as hard as it may seem. On the seat the buckle portions are different since the lap belt isn't needed on the newer interior. These are easy to swap...just held onto the seat frame with 2 10mm bolts.
As for the rest of the project, you will need all the trim pieces for both sides. Obviously the rear panels for the seat belts and also the pillar trim since the auto belt is no longer going to be there...without it it will leave a gap. All mounting points are already in place accept 1, that being the top mounting point for the seat belts....you will understand what I mean when you get there. I just drilled a hole a bit smaller than the bolt and let the bolt tap its way into the metal. If you have any hang ups, let me know. Oh and if you need some pictures look for my thread on the interior swap. -Tim
__________________
Current Collection 1994 Thunderbird SC - Auto - Now 5 Speed 1994 Thunderbird SC - 3v Project 1990 Thunder/Cougar XR7 - 5spd 1995 Thunderbird SC - Auto '90AOD / '90M5R2 / '944R70W - Parts Cars Mn12parts.com - My parts website |
Ken - Check out this thread over on TCCoA. Rod/racecougar did that in his 90 Cougar. I've thought about doing the same thing - I just haven't done it yet.
Also - I believe Candian MN12's don't have the automatic seatbelts if you can find someone parting out a 'Bird from Canada. Don't hold me to this though - I'm not 100% sure on this. -Melon Also - did you get the fan? I dropped it off last night.. just making sure it made it from your son to you ![]() |
Quote:
That really doesn't sound safe at all. That upper mount takes a large amount of force in an accident. That bolt could easily pull right out of the sheetmetal in an accident. You might want to check out my solution to that problem in the writeup I did over at tccoa. Melon posted a link to it above. Melon, You are correct, 89-93 Canadian MN12's came with the manual seatbelts. -Rod
__________________
Rod @ AzzKicker Cars rodsv6cougar@cs.com 90 XR7-The Meth Addict-KB SC'd 5.0L DOHC Stroker 2004 Mustang GT-The Driver-Intake/Exhaust/3.73's 1995 F150 4x4-The Mud Toy-5.0L/4R70W/33's/Warn 8274 Winch 2 - 90 35th Anny Ed SC's And a TON of parts cars! |
| Thread Tools | |
| WTB Seat Belts | super6ter | Want to Buy | 2 | 12-07-2004 10:22 PM |
| motorized seat belts | bossracer | Technical Forum | 2 | 05-31-2004 06:55 PM |
| Seat belts dont work... | DJBreuer | Technical Forum | 7 | 10-20-2003 12:10 AM |
| auto seat belts quit working 1 by 1?? | 35thauto | Technical Forum | 1 | 02-03-2003 06:12 PM |
| seat belts | danekejt | Technical Forum | 0 | 11-07-2002 05:38 PM |
