how do i make my supercharger whine louder
other than a smaller pully, how can you do it?
Remove the air silencer...to make it even louder install a cold air intake that uses a metal intake tube.
__________________
Quote:
there's some on ebay for $62.00 I just type in Thunderbird SC and search.
__________________
Scott Long 1992 SC 5-speed (acquiring parts while in Afghanistan) 1994 SC auto (waiting for me to get back and go pick up) 1990 SC auto (good engine and trans w/ lentech vb, bad electrical, rockers gone, pulling drivetrain this summer to swap) 1990 SC auto (longblock in car w/ trans, getting drivetrain swapped with other 90 SC I have) |
#5
Quote:
You can decide for yourself what you want to do. The metal intake tube is a good start though. PM me if ya have any questions. |
#6
Quote:
how would closing he sound ports make it louder? also would there be any negatives to removing the hood liner? |
#7
hood liner is basically like a heat shield. it helps to keep heat from directly coming in contact with the hood, keeping the hood from deforming or paint bubbling under constant heat situations. might not be a positive idea to remove. i plan to install a "real" hood scoop someday but maybe something like that will increase the noise level of the blower, i don't know for sure.
#8
Like everyone mentioned the most effective way to wake up a blower whine is by removing the air silencer and installing a cold-air kit of some sort. Well, really you get pretty good whine out of anything that isn't the stock airbox. Right now I have the stock intake tube on my car with a 70mm TB and 73mm MAF and just have a cone filter on it and my blower is decently loud. Was even louder with the ZR CAI though.
#9
Quote:
#10
Quote:
http://www.supercoupeperformance.com/ David
__________________
#11
My hood liner has been gone a long time and my non clearcoat white paint is doing fine. Closing the sound ports will make it much louder. They are there to quiet the SC down. It makes it pretty obnoxious loud. It's louder than my Flowmaster exhaust. I had someone who can weld aluminum weld them shut.
#12
Quote:
#13
If you remove your SC top (3.8 stamped on it), You will see a triangular outlet and 2 small slits, one on each side of the outlet. Those are the sound ports. I wouldn't recommend messing around with the Supercharger without experience though. It takes an experienced welder who can weld aluminum to be able to close them like that. That is the only reason mine are welded.
#14
Quote:
My brother never exactly welded them. Funny thing is, I never thought they would last this long. Then I thought to myself, if closing to two small ones will make it loud, I bet you closing the big one in the middle will make it really loud!! Hey, I'm an innovator. Dalke shmalke. ![]() |
#15
ummm.. nothing on ebay??? are you nutz or blind.. I'd check again dude..
| Thread Tools | |
| I found this FAQ on the SC | Active non member | Super Coupe Club of Western Canada | 14 | 11-06-2010 11:31 PM |
| Who make our OEM injectors and does Siemens make injectors to work with our car? | metalman | Technical Forum | 8 | 05-23-2005 10:58 PM |
| supercharger problem | tbirdtony | Technical Forum | 2 | 03-31-2005 08:16 PM |
| 91 Supercharger, plenum, 10%, raised top | eyefly | Parts for Sale | 3 | 01-17-2005 03:12 PM |
| Will removing my cadilidic converter make my car louder??? | RyanJCastor | Technical Forum | 6 | 08-01-2002 12:11 PM |
