Can any body tell me what these codes mean and what direction should i go in for repair i pulled a code:
14 Profile ignition pickup circuit fault 66 Mass air flow sensor circuit out of range(low) 87 primary fuel pump failure 96 fuel pump circuit open, Battery to ECA At first the car just stalled on me like it was not getting enough gas stuttering and bucking out of nowhere got it started and made it home. It did start up several times but soon died before i could make it out of the driveway. now after several attempts it will not start but will crank. I pushed the schrader valve and barely any fuel came out after jumping fuel pump and trying to start car. I have changed fuel filter with no luck old one was clogged barely any air would pass through. Do anybody have any suggestions on which direction i should go? Read wrong codes in original post these are the right ones. Last edited by L.A.TBIRD; 07-06-2005 at 03:52 PM.. Reason: MORE info |
You can test the coil pack, but most likely your DIS is on it'
s way out. |
i have code 66 and 87. what should i check to fix it.
__________________
50pound injectors/80mm maf/85mm/mp/ tb 3.5 cai/snow kit/kw double ic with fan 95-s port blower 10% pulley/mp plenum march underdrives/mandrel bent duel exhaust and flowmaster super 40 mid mount muffler,gutted cat's aluminum jackshaft stock size innovative wideband/qh tuning/ 3:73 gears and mark 8 control arms |
bump any ideas
__________________
#5
Have you cleaned the MAF? Does your fuel pump run at all?
I would check fuses and relays for the pump.
__________________
~Chris SCCoA Member #1826 Riding jack stands. Last edited by BLOWN38; 06-06-2012 at 08:49 PM.. |
#6
yea and even bought a new sensor for my c@l 80mm no change. the fuel pump is barely 3000k miles on it. it's a walbro 255. my guy is trying to tune it but . when he trys to change the a/f it just stays the same and no change is noted on my wideband . it didn't have these codes when i took the car up there a few weeks ago. i went up to help him with the car and these where the codes that i got.
__________________
| Thread Tools | |
| resetting keyless door pad? | obucina | Technical Forum | 11 | 08-31-2006 03:00 PM |
| surging stalling idle and code 42 | Brianas | Technical Forum | 2 | 12-09-2004 05:27 PM |
| 5% Discount code for RockAuto | cp308 | Parts for Sale | 0 | 10-22-2004 05:50 PM |
| keypad code | james5275 | Technical Forum | 3 | 08-23-2003 03:20 PM |
| Code 19? | Jake | Technical Forum | 5 | 05-27-2003 06:58 PM |
