User Name
Password
Reply
Old 07-12-2005, 08:28 AM
dkmccarty5 dkmccarty5 is offline
SC Newbie
Cracked Head ???
Coolant leaking out of the front side of the left head. Looks like it may be a cracked head. Once the head is replaced, is it possible that the rings may be shot due to running it with a cracked head ? i.e. the compression has probably been down on at least one cylinder for a while. Once the new heads are installed, and the compression is back up, I'm wondering if there will be "blow by" in the cylinder(s). Any ideas/thoughts ? The car has 132,000 miles and I'm wondering if it's worth fixing. Everything else seems fine, and the car has been running fine too - even with a cracked head ! Your comments/opinions are welcome !
Old 07-12-2005, 01:13 PM
68COUGAR 68COUGAR is offline
SC Newbie
Send a message via ICQ to 68COUGAR Send a message via AIM to 68COUGAR Send a message via Yahoo to 68COUGAR
Re: Blow By
Quote:
Originally Posted by dkmccarty5
Coolant leaking out of the front side of the left head. Looks like it may be a cracked head. Once the head is replaced, is it possible that the rings may be shot due to running it with a cracked head ? i.e. the compression has probably been down on at least one cylinder for a while. Once the new heads are installed, and the compression is back up, I'm wondering if there will be "blow by" in the cylinder(s). Any ideas/thoughts?
Compression may or may not be down, it all depends on where the crack goes. If it's only from the water jacket to the outside, you shouldn't have coolant in the cyclinders. However if the engine overheated due to low coolant, you may have also blown the HG's.
I'm on my 4th. set of HG's & never had to change the rings or pistons. Cyclinder bores were fine also.
68COUGAR
Old 07-12-2005, 01:23 PM
SC Newbie
Ported Heads
Since you're already gonna be tearing the engine down to replace the head, this would be a good time to get those ported heads you've been dreaming of!!!!!!
68COUGAR
Old 07-12-2005, 03:49 PM
SC Newbie
Quote:
68COUGAR
Thanks "68". The car has never gone full hot - just occassionally gets up to the "M" on the idiot Normal gage. I'm hoping it's just a cracked head and nothing more. No coolant in the oil, no white smoke out the pipe.
  #5
Old 07-12-2005, 04:05 PM
scbirdrollout scbirdrollout is offline
SC Newbie
blown head what too do next
wondering what is the steps need to redo the hg's what all will need to been done and what tools i will need,,,,,,,,,,,,,,talk to you all later
  #6
Old 07-13-2005, 12:38 PM
scbird1 scbird1 is offline
Caution loose nut @ wheel
SCCoA Member #: 2201
If you have coolant from the front of the head, it sounds like a head gasket. The only cracked 3.8 heads I have seen were from spark plug hole to hole. This is there weak spot. Take both heads off and have them checked and resurfaced.
  #7
Old 07-13-2005, 01:27 PM
pablon2's Avatar
pablon2 pablon2 is offline
Mods, mods, and more mods
SCCoA Member #: 2099
68COUGAR
Why have you blown headgaskets 4x? I hope your answer is..."b/c I have 4 SCs!"
__________________
It's only impossible until we do it.
17-year SC owner - '93 SC AOD (non-locking TC)
Current setup: 12.550 @ 111.09, 1.917 60ft, No nitrous.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
I found this FAQ on the SC Active non member Super Coupe Club of Western Canada 14 11-06-2010 11:31 PM
My head gasket how-to Scott Long Technical Forum 21 05-15-2009 01:18 AM
Cracked Head Question???? OzzManG149 Technical Forum 5 01-16-2005 08:26 AM
cracked head!!!!! storey Technical Forum 9 12-29-2002 12:32 AM
