Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 07-19-2005, 05:45 PM
pro street rich pro street rich is offline
Talking getting that hood up and out of the way...
Well as most of you guys know, we move a lot of engines in and out around here. The biggest pain is working around the hood. Well, I am going to share a little trick we came up with.....here goes.
Get a peice of 1 1/2 PVC pipe go with the "40" as it is a lot stronger. Cut it to 25 1/2" long. Now pull the stock shocks off the hood and place this pipe between the pin in the hood and the strut tower on the back side. You only need one of these pipes,you can move it from side to side as your work needs.
This will give you plenty of room to work and even pull the engine out without removing the hood. Sure saves a lot of time pulling and replacing the hood and getting it to fit again...Simple, eazy and it won't break the windsheild, nor do you have to remove any of that stuff either...
Hope this works for you guys and helps to save some time on the next trip under the hood... ..Rich
__________________
Too many cars,too little time to drive them. Anything less than 500 cubes is a small block. If you slow down in life you will get run over..
Old 07-19-2005, 08:24 PM
Scott Long's Avatar
Scott Long Scott Long is offline
Send a message via AIM to Scott Long
I just pull the hood off the car. 4 Bolts and two clips for the shocks.
__________________
Scott Long
1992 SC 5-speed (acquiring parts while in Afghanistan)
1994 SC auto (waiting for me to get back and go pick up)
1990 SC auto (good engine and trans w/ lentech vb, bad electrical, rockers gone, pulling drivetrain this summer to swap)
1990 SC auto (longblock in car w/ trans, getting drivetrain swapped with other 90 SC I have)
Old 07-19-2005, 08:46 PM
Talking need two people, plus aline it....
Quote:
This makes it a one person job, plus you know the hood still fits when you are done... ......Rich
__________________
Old 07-19-2005, 08:50 PM
Scott Long's Avatar
I don't take the hinges off, I take out the 4 star bolts that hold the hood to the hinge. Well my big block car has one of those stripped out, so I'll have to grind it down, or take the hinges off and get new hinges. Although I think I want to try to get a lift off Cobra R hood for that car when the 460 finally takes a home in the car.
__________________
Scott Long
  #5
Old 07-19-2005, 09:10 PM
Talking got some for you...
Got a bunch of hinge's around here, see me when the time is right..........Rich
__________________
  #6
Old 07-19-2005, 09:28 PM
Scott Long's Avatar
Cool.
Do you know if you can get a cobra r cowl hood in lift off form like you can w/ the cervini's? I like the cowl better than the ram air especially for a big block powered SC.
__________________
Scott Long
  #7
Old 07-20-2005, 12:11 AM
quick35th's Avatar
quick35th quick35th is offline
Send a message via AIM to quick35th
Just an idea but why cant you just lay down a blanket on the roof/windshield and rest the hood against it? No unbolting required. Sounds like a good idea to me.
Shane
  #8
Old 07-20-2005, 01:01 AM
racecougar's Avatar
racecougar racecougar is offline
Quote:
Shane
The edges of the hood will hit and crack the glass long before the front of the hood will lay back onto the windsheild. Basically, "it don't work that way". Trust me, a certain person here accidentally did that to one of my cars for me.
-Rod
__________________
Rod @ AzzKicker Cars
rodsv6cougar@cs.com
90 XR7-The Meth Addict-KB SC'd 5.0L DOHC Stroker
2004 Mustang GT-The Driver-Intake/Exhaust/3.73's
1995 F150 4x4-The Mud Toy-5.0L/4R70W/33's/Warn 8274 Winch
2 - 90 35th Anny Ed SC's
And a TON of parts cars!
  #9
Old 07-20-2005, 01:17 AM
quick35th's Avatar
Quote:
-Rod
Ouch! Well I guess I will remember that before I yank the motor out of the 35th then.
Shane
  #10
Old 07-20-2005, 08:17 AM
Talking you are correct on that one...
-Rod
Been there, done that.........agust of wind got one the first time I made one of these pipes. It was longer for "more" room. The hood was almost straight up, and the wind did the rest...That is why you only go 25 1/2 tall.....Thanks for the input Racecougar,[Rod] . ............Rich
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
