Billet parts
I have posted a few items in the past for Heartland fab on pulleys and other parts as well. Heartland is no longer making any billet parts for the SC. I am planning to now continue with several of the parts and would like to begin with a survey on a few group buys. The survey is at www.trumanlake.com/billet and I would appreciate it if anyone was interested to simply fill in a quantity of any of the 3 parts listed that they might want. This survey is only to verify interest in the parts listed. I will begin making the parts as soon as we have a large enough group to make a minimum buy. In the future they will be on the shelf items available in small quantities.
If you have any questions please let me know at training@trumanlake.com Mike |
Mike,
Welcome back!! I went to each one of the three and placed a "1" in each box and hit "Submit" and up comes "page not found". I tried it a few times but the same... Page not found comes up. Not sure if it's just me or if others are having the same problem, but thought I should let you know. Good Luck on All this Mike!! Thank You! Jeff B.
__________________
boostinmy89@eastsidethunderbirds.com '1691' off the line in 89 Born: Feb. 08,1989 Powered By: Magnum Powers MPIII - w/CUSTOM FMIC260 RWHP / 346 RWTQ @15.9 lbs Of Boost
page not found
When I posted the survey I put it up before I loaded the redirect page and so it gave a page not found reply.
That should be fixed now. Thanks for the reply as that will help me to know where to start with the parts. I am glad to be back with the group. Mike |
Welcome back Mike! Drop me an email sometime so that we can catch up.
Do you plan to make the SC Shootout? |
#5
Well, I voted for the sill plates. But would it be possible to leave the "SC" off of them for my set? They would be going on my 90 XR7.
-Rod
__________________
Rod @ AzzKicker Cars rodsv6cougar@cs.com 90 XR7-The Meth Addict-KB SC'd 5.0L DOHC Stroker 2004 Mustang GT-The Driver-Intake/Exhaust/3.73's 1995 F150 4x4-The Mud Toy-5.0L/4R70W/33's/Warn 8274 Winch 2 - 90 35th Anny Ed SC's And a TON of parts cars! |
#6
Quote:
__________________
Kurt K (e-mail) SCCoA Member #: 443 '92 SC AOD -- 11.521s @ 116.748mph, 2.0 AR power . . . . . . . . . -- 13.547s @ 101.01 mph, only w/ bolt-ons '95 SC 5spd -- All Stock, except 17" Simmons wheels. '90 SC 35th Anny 5spd -- 3rd owner, 16k miles 2 '89 XR7 5spd's -- on their way out, really! |
#7
Quote:
-Rod
__________________
#8
I also voted for sill plates. I think they will look really sharp!!
Thomas |
#9
how about making more P/S pullies? I know the design before had issues, maybe try something different. I got a good and simple design in mind with a press on hub, but the pulley will bolt to that instead. Its something I could model up and have a proto-type made if anyone is interested.
#10
text
I can leave the sc off of it and add xr7 or leave it blank. the space provided can say anything.
There will be a variation of what is available soon so any ideas you have are welcome. I hope to have enough information by the middle of August that I can get some idea of what you all will want. Mike Quote:
#11
Quote:
Mike |
#12
That sounds great, Mike.
-Rod
__________________
#13
Quote:
The pulleys had a minor but noticable impact on useability. Some worked but some did not. To me this means a minor problem even though it was major to those who it did not work for. I really think the problem was in tolerance and not design even though I personally do not like the mounting design. A bolt on or pin design of some sort seems in order to me just for the fact that spinning parts are harder to handle that stationary parts. The real problem to me is the hub mounting design of the previous parts made. The hub tolerance seemed to be inconsistant with pump shaft size. Also Mike says it was a tapered arbor which I can find no data to back up the taper theory. I feel it is a press fit which takes other tolerance values. I do not have any figures on the mis-alignment of pulley ribs and what is too far out of tolerance to accept for a useable situation. I would like to talk about this further but actually I feel I can still build a full set of custom pulleys for the front of the SC reducing HP requirements and adding to the asthetics of the engine. Mike |
#14
definately interested in the sill plates
#15
Hey Mike Im glad to hear from you again. If there are any other parts you are going to need that are not SC specific, I have a LX out back of the house that I am pulling parts on now. I also would like to get with you because I still want a quick change set for the blower. Glad to see you found someone to help out on this.
Chris |
| Thread Tools | |
| '93 + front spindles (parting out '94 SC) MANY PARTS!!! | Mercury267 | Parts for Sale | 11 | 11-28-2012 03:06 PM |
| SC & MN12 Parts - Large Inventory | racecougar | Parts for Sale | 91 | 02-14-2011 09:33 PM |
| SC/MN12/FN10 Parts - Very Large Inventory | racecougar | Parts for Sale | 120 | 01-24-2006 06:30 PM |
| '94 SC and 95 Mark VIII LSC parts ready 4 sale | Mercury267 | Parts for Sale | 9 | 09-29-2005 05:21 PM |
