User Name
Password
Reply
Old 08-29-2005, 09:11 AM
Roadhawg Roadhawg is offline
SC Newbie
ARP Head Studs
I have seen different post on this which is the best choice?
ARP-153-4001 ARP Cylinder Head Stud Kits
Cylinder Head Studs, Hex Nuts, Ford Thunderbird Supercoupe, 3.8L, Kit
ARP-233-4003 ARP Cylinder Head Stud Kits
Cylinder Head Studs, Hex Nuts, Chevy V6, 2.8L, 60 Degree, 11mm, Kit
Thanks
Old 08-29-2005, 03:36 PM
edspringer edspringer is offline
SC Newbie
SCCoA Member #: 1496
I used the ARP Ford set
I just installed the ARP Ford kit in my 94 SC. I got it from Bill Evanoff @ SC Performance. Real easy to do with allen head studs. I tapped each head bolt hole in the block just to clean them out. I sprayed carb cleaner in each one and then blew out with air. The only issue I had was if you screw in the shorter studs (bottom row next to the exhaust manifold) all the way in there is not enough thread on the front and back studs to fully torque the nut. I put the washer, moly lube and nut on and then, with a allen wrench, back the stud out just so it was even with the top of the nut. When I finished torquing the heads, I had a little more then one thread proturding above the nut and that is all you need.
Ed Springer
90 Black XR7 5-speed: 70mm TB, Fresh Air Intake, '94 Supercharger, 36# injectors, 190 l/h fuel pump, 5% SC Pulley, 180° Stat, Raised SC Top, I/C Fan, UD Pulleys, Headers, Magnaflow Muffler (no cats) with stock resonators, 3:27 Gears, Rear Spring Air Bags, Ripper Shifter, 73 C&L MAF (Blue Tube), Magnacore Wires, NGK Iridium Plugs, Royal Purple Synthetic Lubricants.
94 Red SC Auto: 70mm TB, Fresh Air Intake, Stock 90 SC Pulley, Accel 36# injectors, Scorpian 1.73 Rockers, ARP Head Studs, 190 l/h fuel pump, 180° Stat, Raised SC Top, I/C Fan, Headers, UD Pulleys, Raven Muffler (no cats) with stock resonators, 3:73 Gears, 76 C&L MAF (Gold Tube), Magnacore Wires, NGK Iridium Plugs, TRANSGO Shift Kit, Haydon Auxiliary Transmission Cooler, ProTorque 2500 TC, Tokico Struts & Shocks, Royal Purple Synthetic Lubricants, American Racing 17” Sniper Wheels, Michelin Pilot Sport A/S.
Old 08-29-2005, 04:50 PM
68COUGAR 68COUGAR is offline
SC Newbie
Send a message via ICQ to 68COUGAR Send a message via AIM to 68COUGAR Send a message via Yahoo to 68COUGAR
Excellent
Quote:
EXCELLENT idea!!!!!!!!!!!!!!
68COUGAR
Old 08-30-2005, 01:33 PM
Danzajax Danzajax is offline
SC Newbie
SCCoA Member #: 3231
Send a message via AIM to Danzajax
Get the chevy 2.8!!!!!!
I just put the chevy 2.8L studs in my car. Worked beautiflly. Just thread in the studs and place the head on.
I talked to someone with the ford 3.8L set and they had to grind on the exhaust manifold. The car is going strong for over 500 miles now. I was very happy with the 2.8l Bolts (as there cheeper)..
-dan
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
SC Head Torque Using ARP Studs.....Question? edspringer Technical Forum 1 08-24-2005 09:28 AM
ARP head studs vs. torque to yield - madness 89psychobird Technical Forum 25 04-22-2004 09:21 PM
ARP Head STUDS Conan56 Technical Forum 3 04-24-2003 01:03 PM
