What was that source for coated rotors??
Hey guys, I remeber someone selling coated rotors from the Grand Prix and I cannot find that info anymore???
I am looking for a set... Thanks!
__________________
1990 35th automatic... Last edited by sizemoremk; 09-01-2005 at 02:06 PM.. |
ESM is selling rebuilt coated rotor packs..Paul at BTM is a good contact for that but I dont think they are cheap
Yeah, but someone here was selling used grand prix rotors for a decent price....
I can't find the thread anymore...
__________________
1990 35th automatic... |
Here is the website
http://www.thehighspeedlab.com/ sales@thehighspeedlab.come Costs are around $350 uncoated and $450 coated. I beleive he offers a discout to SCCOA members. Last edited by Shockwave; 09-01-2005 at 05:58 PM.. |
#5
Coated rotors
Go to
www.ClubGP.com Join and make a posting there in the wanted section You will get tons of offers ranging from 50-150 for a set Its very easy to install But IS NOT a direct bolt in The dowel pins do not align cause they are in different positions Ill give you an easy solution Last edited by Conan56; 03-25-2007 at 06:59 PM.. |
#6
Quote:
You just move pin right?
__________________
#7
You are right!!!
Yep you move the pin and it will fit.. Oh yeh and I think I had to drill it out to a 25/64..... Also the dude does a good job on shipping and the rotors not being chipped!!! I put a set in MPII...... Worked like a charm.. No need to pay 400 bucks for them....
Quote:
__________________
Anthony Arnold www.letsrace.org Home of "No Cash Racing!" Silver 90 AOD 12.04 Black 92 AOD 12.77@109.5 10/12/07 |
#8
heres the thread
__________________
#9
Rotors
Moving the Pin is more work then you need to do
Moving the pin can also be a pain to gett he pin out All you need to do Is redrill the case to accomadate the Pin Just redrill down approx 5/16 of an inch so the pin sinks into the hole Plenty of The threads will still be in the bottom of hole Also redrill the Snout holes to a larger size to accomadate the pin also It takes Maybe 5 min to drill both Holes to the larger size Then seal it back up and bolt it back together Ive been doing these for years already Its a very Simple and cheap upgrade It was worth like 2 lbs of boost on my Magnaport 2 Only issue with using GTP rotors is that most of them when you recieve them will be discolored from carbon because of the EGR system DO NOT I REPEAT DO NOT attempt to clean the rotors with anything you will remove/damage the coating All It is is discoloration and Doesnt affect anything |
#10
I bought a set of GTP rotors from a guy off of clubGTP, and modified an extra M90 case for them by drilling out hole in the case for the GTP dowel. After I was all done I mounted the rotors and they had bad bearing in the rotor pack. I think someone had overheated these rotors as the coating was extremely delicate and would peel right off at the slightest touch. So in the end I reused my original uncoated rotors on my SC rebuild.
Jerry |
#11
The scum on the GTP rotors from the egr is the best part, When I first put mine in, it went like a cracked out raped ape, but as the pcv oil coated them, they got cleaner and the car lost some spunk. Ed Morad sells excellent rotors by the way, the extra mods you gotta do is totally worth it.
#12
Who is Ed morad and I been trying to get some of these for the longest..I need a set badly
#13
Hell Damon why didn't you ask me? I have sent about 6 people his way in the last few weeks.
Shockwave I don't know what kind you got but the ones the coating is nearly bullet proof. I have sprayed Carb cleaner, brake cleaner, every solvent in my garage and the stuff doesn't come off. Not like the 94-95 SC rotors. Jeff |
#14
Well he aint got none right now
__________________
#15
Coated rotors
UMM
You guys do all realize that Ed Morad isnt the only guy that sells Blowers and Rotors right? Like I said previously in this post Join and put a post in the Wanted section Thats what I have done and I got multiple sets this way GTPMorad is a excellent seller but he is NOT the only seller The site Im refering to is WWW.ClubGP.com Last edited by Conan56; 09-02-2005 at 11:27 PM.. |
| Thread Tools | |
| Special Discount on SP Performance rotors and pads! | victor malvar | Group Purchases / Specials | 22 | 03-26-2009 03:36 PM |
| ?s about replacing 90 rotors | S_Mazza | Technical Forum | 5 | 02-09-2005 07:55 PM |
| Any one having problems with Raybestos/United Brake Rotors? | Dan Lineback | Technical Forum | 10 | 02-09-2005 07:44 PM |
