Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 11-04-2005, 05:38 AM
Jacob_Royer's Avatar
Jacob_Royer Jacob_Royer is offline
Its Alive!!!!!!!!!
SCCoA Member #: 3178
AOD Upgrades?
Thinking about a shift kit.. What is a cheap way to make firmer shifts with an AOD without making it to stiff for a daily driver? Also whats the stupid deal with not being able to select 2nd gear on an AOD?
__________________
93 SC Auto 111k Member #3178
Fresh Motor
272 Comp Cam,ARP head studs
Ported and polished heads and intake,Ported late model blower, MP Inlet Plenum 10% od, 76mm Maf & TB , 42# Injectors, Full Exhaust
~96 Mustang GT 5speed 350k+
~99 Cobra 120k 312rwhp/320tq
Old 11-04-2005, 08:51 AM
Kurt K's Avatar
Kurt K Kurt K is offline
Still slow
SCCoA Member #: 443
Quote:
A Lentech Valve Body will fix your problems. The Shifter pattern becomes P-R-N-D(OD, when electonic switch is disabled)-2-1. If you aren't familiar, the Lentech VB uses an electric solenoid to 'lock out' OD and then revises the shift pattern to shat is listed above. Art Carr also make something similar, but hydraulically locks out OD under full-throttle only. I've had both and much prefer the Lentech.
Edit: I just read "cheap" in your post. I think either VB is in the $400 range, which you may not consider cheap, but you won't be disappointed as long as you tranny isn't already on its last leg.
__________________
Kurt K (e-mail)
SCCoA Member #: 443
2 '89 XR7 5spd's -- on their way out, really! Any Offers?
Old 11-04-2005, 09:34 AM
David Neibert's Avatar
David Neibert David Neibert is offline
Still loves the Cobra Rs
SCCoA Member #: 858
Yeah...get the Lentech VB, you won't be sorry.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
Old 11-04-2005, 11:04 AM
quick35th's Avatar
quick35th quick35th is offline
Autocross Terror
SCCoA Member #: 2313
Send a message via AIM to quick35th
B&M and Trans Go make shift kits for our cars. I think the Trans Go is just over $100 too. I have never used either of them so I cant tell you which is better. I am a sucker for 5spd SC's
Shane
  #5
Old 11-04-2005, 12:16 PM
Kurt K's Avatar
Still slow
SCCoA Member #: 443
Quote:
Shane
Granted the B&M and TransGo shift kits are cheaper than a complete VB, but you still have to deal with the original shift pattern. Also, some will recommend the TransGo because it allows full-throttle upshifts into OD, but since the OD band is the known weak-link of the AOD, I definitely wouldn't want that.
__________________
Kurt K (e-mail)
SCCoA Member #: 443
  #6
Old 11-04-2005, 12:52 PM
SCCoA Member #: 858
I had the Trans-Go set to medium firmness, and I even thought it was a good shift kit...until I got the Lentech VB. The Lentech with level II calibration shifts softer when allowed to shift automatically and harder when shifted manually. Being able to lock out OD is very helpful on the dyno and the track, because with the Trans-Go it will very often shift into OD even though the shift lever is in "D". Bieng able to hold 2nd gear up or downshifting is even cooler.
When you consider the time/cost to install the trans-go kit as opposed to just bolting on the Lentech VB, the cost of going with the Lentech is nearly the same. You don't have to wire up the OD delete solenoid, but it's not difficult and only requires one small hole to be drilled for the 12 volt power supply wire.
__________________
  #7
Old 11-04-2005, 01:21 PM
Blown 91 Bird Blown 91 Bird is offline
SC Newbie
Send a message via AIM to Blown 91 Bird
I have a stock (rebuilt) aod in my SC and i can hold every gear til redline. To control the 2-3 shift you gotta pull the shifter back down into 1st after it shifts into 2nd, then shift to 2nd for it to go into 3rd.
I usually just let mine shift on its own since under WOT it shifts at about 4600.
  #8
Old 11-04-2005, 01:24 PM
SCCoA Member #: 858
That's called shovel shifting and it's very hard on the transmission.
__________________
  #9
Old 11-05-2005, 11:14 AM
Mike Puckett's Avatar
Mike Puckett Mike Puckett is offline
SCCoA Member #: 272
I just put a Performance Automatics 53301 in my 35th. I got it from Jeg's for $190. It might a lesser cost alternative. It's only been in for a couple of weeks on a newly rebuilt AOD so I'm still breaking it in. It shifts much quicker and firmer than before.
__________________
90 5spd, best E.T. 12.250
best 1/4mi speed 112.89 mph
best dyno 388.42 rwhp 419.68 rwt
2004 Cadillac CTS, 14.616 @ 91.84mph.
  #10
Old 11-05-2005, 11:52 AM
CaifanSC CaifanSC is offline
SCCoA Member #: 1257
Send a message via AIM to CaifanSC Send a message via Yahoo to CaifanSC
Are any other upgrades to the AOD other than shifkits/valve bodies? Im not too familiar with anything else except i've read of 'hardened shaft' or somethign like that and just recently an aluminum flexplate? Does anybody feel like educating a fellow sc'er?
__________________
1993 SC 5.0L Auto Red, 1995 SC 5-speed Chameleon Blue
1992 Feature Mustang Convertible 5-speed Vibrant Red, 1991 BMW 850i 6-speed Brilliant Red (V12 )
Sold: 89 SC stick Titanium, 90 35th stick, 92 Sport 5.0L stick, 94 SC stick Black, 1994 SC Auto Teal Totaled: 89 SC auto Twilight Blue
  #11
Old 11-05-2005, 01:03 PM
SCCoA Member #: 272
Get a heavy duty type of rebuild kit with kevlar bands and clutches and not the standard stock rebuild kit.
__________________
  #12
Old 11-05-2005, 02:23 PM
SilverCasket's Avatar
SilverCasket SilverCasket is offline
SC Newbie
SCCoA Member #: 1800
Send a message via AIM to SilverCasket Send a message via MSN to SilverCasket
This maybe the silliest thing I've heard, but since you asked about the cheapest way. .. There is a trans guy that said when someone wants a shift kit, he cuts the spring (what spring I don't know, someone that shows trans may know) that has something to do with the shift & by doing that it makes the shifts faster. ..
I don't recommend because I have no idea how it works or what the hell he's talking about. .. But it wouldn't cost anything (at first). .. .... Just passing off funny info on what this dude does when he does the tran's there.
ps-Get a lentech
Anthony
  #13
Old 11-05-2005, 07:40 PM
trife86 trife86 is offline
SC Newbie
SCCoA Member #: 2753
Send a message via AIM to trife86
i have the art carr valve body and no complaints, i like it
  #14
Old 11-05-2005, 10:50 PM
txsc's Avatar
txsc txsc is offline
Be Original
SCCoA Member #: 2590
"Experienced" Transmission
Can I use the Lentech VB on an "experienced" transmission with good resluts? I'd like to upgrade, but don't want to cause the trans to grenade. The AOD works fine now, just has that crappy shift feel. And, I don't like back-shifting it manually, because that seems like abuse.
I realize it'd be better to install the Lentech into a fresh, crisp, newly-rebuilt AOD, but if I can get away with it on my used one, that'd be good for right now.
Thanks,
JD
  #15
Old 11-06-2005, 09:16 AM
SCCoA Member #: 858
Yes.... you can install the Lentech or any other shift kit in your used transmission.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
A good post I found for you AOD guys out there. Wayne Ing Super Coupe Club of Ontario 4 12-31-2005 11:05 AM
AOD Upgrades Mike8675309 Technical Forum 15 06-11-2005 07:45 AM
Parting 93 SC AOD with "Ram Air hood" sizemoremk Parts for Sale 27 05-04-2005 08:00 PM
N/A t-bird AOD -vs- SC AOD???? LightY3arZ Technical Forum 23 02-27-2004 01:23 AM
FS: AOD upgrades Turbo351 Super Coupe Club of Ontario 13 09-26-2003 11:02 AM
