Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 11-14-2005, 02:13 PM
CMac89's Avatar
CMac89 CMac89 is offline
Send a message via AIM to CMac89
How much boost did you lose?....
Just wonderin how much boost you guys lost when you put on a set of ported heads and/or a cam.
I am running about 16psi at 4K so I don't think I lost any boost. I'm also running a stock IC though.
__________________
CORN GAAAAASSS!!!
Old 11-14-2005, 02:26 PM
David Neibert's Avatar
David Neibert David Neibert is online now
SCCoA Admin
I didn't loose any. I'm on my 4th cam and boost was about the same with all of them.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
Old 11-15-2005, 09:59 AM
Thunder427 Thunder427 is offline
according to previous owner , mine went down almost 3 with the exhaust ( 5% OD gave it back ), which is basically straight pipes, im putting back some ok flowmasters on it though.
heads are ported, gasket matched, but saw no loss with that.
runs 12-14 PSI.
Old 11-15-2005, 11:03 PM
Blown 91 Bird Blown 91 Bird is offline
Send a message via AIM to Blown 91 Bird
from what i have read, stock 91's usually make like 12lbs of boost. Since the motor in my car was blown up when i bought it i dont know what it made with untouched heads & lower intake..
but right now i make on average 9-10lbs, so i guess i lost 2lbs or so from opening up the heads & intake. But who knows if the stock guage is even telling the truth.. i will find out for sure when i finally actually put the autometer guage i have sitting here in.
  #5
Old 11-15-2005, 11:10 PM
Roadhawg Roadhawg is offline
I'm running only 12 pounds of boost on a stock 92 M90 with a 10% OD pulley.
I'm using a stock NA Cam, Stock SC heads. But I do have shorty headers and true dual exhaust.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Boost leaks, what they do and how to deal with it Vernon Technical Forum 27 04-16-2013 12:19 AM
New fuel pump results in boost gain Night Wing Technical Forum 2 01-10-2005 01:40 PM
conventional plugs, superchargers and dyno tune tbird91sc Technical Forum 11 07-02-2003 03:38 PM
Boost leaks, what they do and how to deal with it Vernon FAQ Forum 0 03-05-2003 04:03 AM
