Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 12-17-2005, 04:50 PM
Rick Mink Rick Mink is offline
need advise quick
my g/f is gonna buy me 2 of my 4 new tires as long as I can order them today. I was looking at the bf goodrich kdw. my question is how wide of a rear tire can I go. I was hoping to go with a stagered setup. 245/40/18 up front and 265/35/18 out back. will this setup work? or will it rub. the car hasnt been lowered. I'm not sure if the tires will be the same height.
Rick
Old 12-17-2005, 05:26 PM
I see they also have a 275/35/18. Which set up should I go with??
Rick
Old 12-17-2005, 07:45 PM
XR7 Dave's Avatar
XR7 Dave XR7 Dave is offline
ask questions-get beat up
Assuming you have the wheels to go with them, I'd go at least 275 in back. I run 285's on mine but I have custom wheels and rolled fender lips. No rubbing though.
edit:
245/45/18 on 8.5"s on front and 275/40/18 on 9.5's in back would be tight. 26.6" nominal diameter. (stock height)
__________________
Email me here.
Old 12-17-2005, 07:52 PM
83GT460 83GT460 is offline
Quote:
I have 295/35/18's on mine and like David since having rolled the fenders I have no rubbing with wheels designed for a 2005 Mustang.
Charles
  #5
Old 12-17-2005, 08:01 PM
what size fronts are you running with those big *** tires??
Rick
  #6
Old 12-17-2005, 08:24 PM
Duffy Floyd Duffy Floyd is offline
Send a message via AIM to Duffy Floyd
One thing to keep in mind on tire selection is if the diameter of the front tires
compared to the rear is to different you can cause problems with the ABS System. The system will "see" the diameter difference as a difference in rotational speed and can cause the ABS system to actuate too early or too late depending on the situation. Also you can throw a ABS light as well.
__________________
22 year SC Owner GFP
(Glutton for Punishment)
1992 5 Speed SC one of 1256
1995 5 Speed SC one of 574
  #7
Old 12-17-2005, 08:54 PM
Quote:
Rick
I have 245/40/18's on the front and while Duffy is probably correct about the tire mismatch, my rears are only about 1/2 inch taller than the fronts and I have not had any issues with ABS. The only time I notice the ABS light coming on is while doing a burnout at the track or on the dyno. If you do a search on my user name you can see pictures with them both on and off the car.
Charles
  #8
Old 12-17-2005, 09:59 PM
XR7 Dave's Avatar
The tire sizes I listed have the exact same diameter front and back.
__________________
Email me here.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Engine swap into a Taurus - Need Advise??? EagleFish Technical Forum 19 12-06-2004 11:32 AM
Quick Help on Drag Tire Selection fastsc92 Non Technical Forum 7 07-10-2004 01:25 PM
FINALLY picked up my car today...couple of quick questions. HK416SC Technical Forum 5 08-11-2002 05:55 PM
