Finally got my engine back
After what seemed like forever, two years actually, I finally got my engine back at my house. I can't tell you how excited I am that I am finally going to get this thing back together. I've had quite a few delays waiting for parts, heads, bolts and just about anything else that could slow me down, but I'm finally making some head way. I've been working on my Sc for about 10 years now and should basically have a new car by the time this is all together. I'm including a few pics so you can see my work in progress. Let me know what you think. I powder coated the thermostat housing and a few pullies in chrome smoke. I glass beaded the water pump, and lower intake. The lower intake looks awesome, too bad you'll never really see it. Like the stainless polished bolts?? In one of the pics you can see the exhaust ports on my Supercoupe Unlimited heads. Welded ports? What welded ports? Imo nice work, dave! Hope you guys enjoy. More to follow.
Rick |
Quote:
Thanks Sprout. I just had the headers on both sides and they cleared the bolts fairly easily. Didnt take any pics yet. I was putting on the engine mounts and noticed that the oil pan seemed real loose. Further inspection revealed that it was only being held on by four bolts. ~~~!! The damn shop even forgot the rear main seal!! I looked in the box of stuff I got back from the machine shop and low and behold, there are my oil pan bolts and rear main seal. I called up the machine shop and asked if there was any reason my oil pan was was not on correctly. The shop seemed to think there was some reason that they didnt put it on. Needless to say I was a little pissed and told them so. That just makes me leary about the whole deal. He agreed to come down and install the rear main seal and oil pan for me, but I;m still not happy. I could easily put it on my self but I want the owner to come down and check everything out before we put the pan on. GRRRRRR. Like I said in my first post, anything to slow me down.
Rick |
Looks good. Flip the engine over and check the torque on the main caps and rod caps. Just to be sure. Then put the silicone on the bottom and bolt up the pan. The rear main just taps in.
__________________
Scott Long 1992 SC 5-speed (acquiring parts while in Afghanistan) 1994 SC auto (waiting for me to get back and go pick up) 1990 SC auto (good engine and trans w/ lentech vb, bad electrical, rockers gone, pulling drivetrain this summer to swap) 1990 SC auto (longblock in car w/ trans, getting drivetrain swapped with other 90 SC I have) |
#5
did you try and put the bolts on the headers? The flange clears the head studs its the bolts that done, I had it wrong.
#6
I used they same kind of stainless cap screws on the headers as I did on the intake. I'm using those stainless bolts for the intake, throttlebody, thermostat housing, fuel rail, headers, supercharger snout, raised top, and the sc itself (big honkin bolt). I guess that actually worked in my favor. who would of guessed. I just went out side and tried to take a pic but my camera crapped out on me and its too cold out there to mess with it. I'll take somw photos tomorrow. I could definately see that I would have clearence problems with stock bolts. Funny, I didn't even notice how tight that would have been until you mentioned it.
Rick |
#7
Looks real nice! I can;t wait to be in your shoes. I too have been waiting over 1.5 years to get my car back together, mainly due to a string of bad luck and bad business. Did you get your valve covers powder coated? I brought mine in to be powder coated and the guy was hesitant to do it b/c of the seal on the PCV ductwork on the underside. He figured the 400deg bake process would melt it. What did you do?
__________________
It's only impossible until we do it. 17-year SC owner - '93 SC AOD (non-locking TC) Current setup: 12.550 @ 111.09, 1.917 60ft, No nitrous. |
#8
Valve covers
Also wondering about the valve covers.
#9
Damn that looks nice! Hurry up and post more pictures.
#10
what seal uunder the PCV? There is just a baffle unnder there no seal. The rubber piece on the top of the valve cover that the PCV pushes into can be removed. I powdercoat valve covers all the time. WHo did your powdercoating anyways?
#11
Quote:
You wouldn't be trying to speak for all SC valve covers would you? I'll take a pic of what I am talking about b/c I cannot seem to explain it with words.
__________________
#12
ok, here are some more pics as promised. The first one is the header bolts to head stud clearance. I never even realized how close that was since I didn't have a problem. The valve cover are painted, badly at that. I had them painted the same time as I had the body done. I love the color, but hate the paint job. I'm looking into repainting it as we speak. I painted the end tanks of my rad and only polished the top of the tank. I like the contrast. I'm plan on powder coating the 85mm t-body and the sc top. I might paint the 3.8 and stripes the same color of the valve covers but I havent decided. Check out that big ~~~ shiney SC bolt. I love that thing, and shiney and sexy. I think they dress up my old s-port nicely. If you look at my intake elbow you can see where I had that modified years ago. Talk about old school. oh well, that was before there was a mp inlet around. enjoy the pics.
Rick |
#13
May I ask why hou have not had your headers coated? IMHO it is well worth it, espically under a stock hood.
Chris |
#14
Looks awesome. The hard part about wating 2 years and then finally seeing the light is refraining from halfazzing things to get finished. Make sure you keep the same focus. I have seen two many guys rush the final touches and booger up the effort they put in at the beginning. Good Luck
What type of headers are they. |
#15
The headers have a high temp powder coat.
Rick |
| Thread Tools | |
| Boost leaks, what they do and how to deal with it | Vernon | Technical Forum | 27 | 04-16-2013 12:19 AM |
| Finally back together and WOW!!!!! Thanks for the help! | edspringer | Technical Forum | 1 | 09-20-2005 02:47 PM |
| finally got my cougar back | Kyler | Technical Forum | 0 | 06-02-2005 11:54 AM |
| Boost leaks, what they do and how to deal with it | Vernon | FAQ Forum | 0 | 03-05-2003 04:03 AM |
| FINALLY!! i got my sc back today | HappyHourHero | Non Technical Forum | 1 | 10-03-2002 12:17 AM |
