#16
I know for sure that it will fit as I have ridden in a 91 T-bird with a T-56. There is a guy that doesn't post much on any MN12 based forums that lives in Rome, GA that converted his 5.0 car to a hydraulic setup T-5, then turned around a couple years later and put in the T-56. The car is wicked as hell too as it has a 331 twin turbo setup to go with the 6 speed. I could ask him to do a writeup about the conversion....
#17
There is not alot of information from people that have done this. I did not get to hear about the one that was attempted/completed? in an SC.
A new updated parts list can help get more people that are on the fence of this to take the jump. The GTO T-56 is said to be stronger then the older camaro/firebird model. It is also supposed to put the shifter very close to the stock tunnel opening. Most people know that with the MCleod adapter, it can be bolted up to a 3.8l/5.0l/5.8l, and different driveshaft length and modification to the cross member are necessary. But that about where it stops for common knowledge. The other pieced that are of interest is what clutch, flywheel, slave cyl., starter are necessary to make it work. Ford Racing catalogue has the T-56 for 5.0ls but we still have the shifter location with those units. And I think it is cable clutch still. $2400.
__________________
1994 Supercoupe 5spd Custom Modded. 2010 Shootout-Best Custom Award-415WHP off the bottle-12.2535 @112.18 off the bottle. Best HP to date 445whp Best TQ to date 516ft/lbs Modified with the 1% $$ 1990 35th 5spd 2011 Carlisle 1st place class winner. 12.9@108MPH 1.9/60fts Modified with the 99% $$ 2 SCs 12sec club member. |
#18
If you're gonna keep your car under 600rwhp then a T-56 from newer generation may work. For certain, the ones out of the Firebird and such from GM are not strong enough for our cars if pushing over 300lb/ft of torque. The Viper gear set would work from that era of T-56. That's when I was looking into it. I haven't dug around since.
Last time I looked (2 years ago) the T-56 was getting into the Hot Rod aftermarket big time with all sorts of options available including different tail shaft housings, shift lever positions, and different gears, mix and match stuff. I figured that I could find whatever I need when I'm ready. Tremec has the torque ratings published on their site.
__________________
90 SC AOD 93 SC 5spd -441hp/462tq *SOLD* |
#19
I noticed that they have a form for manufacturers to fill out.
I wonder if we get enough people in a buy we can get something custom set up to be a simple drop in. Before we can ask them we would need measurements for our stock M5R2. ![]() Size A Size B Size C Size D Size E Size F Size G Size H Input Shaft Pilot Dia. Input Shaft (Spline Count) Output Shaft (Spline Count) Output Shaft Design flange slip yoke
__________________
#20
When I talked to a Tremec tech rep last year he recommended the TKO.
__________________
90 5spd, best E.T. 12.250 best 1/4mi speed 112.89 mph best dyno 388.42 rwhp 419.68 rwt 2004 Cadillac CTS, 14.616 @ 91.84mph. |
#21
Subscribing - something that I would like to do.
__________________
1989 Cougar XR7 - Modified 1967 Cougar XR7 - untouched - 2011 F350 Crew Cab Superduty FX4 6.7 diesel 435hp/800 ft lbs torque 2009 Smart 2010 Harley Davidson Ultra Classic |
#22
This has been talked about quite a bit. Here is a thread over on TCCoA that has a image of the M5R2 trans and dimensions.
http://forums.tccoa.com/showthread.php?t=55283 Note that the future of manual transmissions is going to be the dual clutch transmissions. Their quite cool, and once they get rolling, their torque capacity should be quite nice.
__________________
90 SC AOD 93 SC 5spd -441hp/462tq *SOLD* Last edited by Mike8675309; 06-23-2008 at 01:32 PM.. |
#23
I don't know where these ideas come from. Stock LT1's made over 300ftlbs torque. The transmissions being referred to here might not stand up to 5500rpm clutch dumps, but neither will your axles. I would have no reservations about putting one in my car. They are stronger than an M5R2.
__________________
Email me here. |
#24
Quote:
__________________
#25
Quote:
Viper transmissions have unique spline counts. 26 on the input 30 on the output. Fbody's have 26 on the input, but 27 on the output. Fords have 10 on the input and 31 on the output. It's a very doable swap if someone has the time and a transmission.
__________________
#26
t-56 pics
here are some pic of the eng/belh/trans plus some
#27
more t56
here are some parts/boxes with P/Ns
#28
notes
did some measuring last night after work.
the center of the shifter on the t56 is maybe a little under an inch forward of the m5r2. The trans looks to be about an inch shorter, but the trans mount is farther back 1-1 1/2". The splined portion of pilot shaft goes into the crank pilot cavity about 1/4" maybe a tad more. (maybe a weld up and turn down to ford spec for some industrious person?) Don't have an in the car fit up yet, have to call the machine shop to get pricing for work on engine. Until the engine goes away for work I going to use it to fit as much as I can. MikeH |
#29
Was looking through a bunch of downloads and printouts here are a couple of tid bits.
Here are the McLeod parts recommended by Billy M (Tech advisor @ McLeod) 260571 is a 26 spline 11" disc for the LS1 T-56. 361954 P/P (going to use the Sach's I have <2000 miles) P20810 Pressure Plate Shim. No you do not need to change your slave. (changed same time as P/P) Haven't found anyone with the shim or any info about it. This may actually be easier than it sounds? MikeH |
#30
Trying to understand your notes.
The input shaft is too long where the pilot bearing is or is the spline part too bid and push/hit the pilot bearing. I am also not following what clutch components you are going to use, are you using a LS1 T-56 clutch/pp with a 26 spline disc. And a stock LS1 slave or the stock SC slave? Quote:
__________________
| Thread Tools | |
| What's the best way to install engine???? | MagpoweredSC | Technical Forum | 4 | 03-22-2005 10:56 PM |
| Must I remove the radiator to install a double intercooler? | hellakornhaus | Non Technical Forum | 9 | 09-29-2004 02:58 PM |
| 347 install nightmare | David Neibert | Non Technical Forum | 19 | 07-20-2004 03:50 PM |
| rebuilding engine (any tips) | creeperxr7 | Technical Forum | 74 | 11-15-2003 12:23 AM |
