Thanks Wynn!
For the past month or so I have been searching for a dip stick tube for my 95SC and since Ford no longer feels the need to supply parts such as this it has been disappointing to say the least. Today however I decided to drive over to Beaumont to visit with Wynn to discuss a project that he is working on for me and while I was there he hooked me up with one of the obivously rare 94-95 dip stick tubes and so I wanted to take a minute to say thanks to Wynn.
Charles |
Wouldnt a dipstick tube out of a 94/95 NA 3.8 work?
Quote:
Charles |
.. Ive been looking for one of those for the last 6 months.
Does he have any more ????? - Dan |
#5
Quote:
No they are not my friend. I did an article for the upcoming Charging Thunder about adding a windage tray to 89-93 engines and as part of the article I compared the 89-93 and the 94-95 dipstick blades and their corresponding tubes. I must tell you they are exactly the same...one will work to replace the other. The only differences are the way the dipstick blade seals with the tube. The 89-93 blade just sort of seals over the tube, the 94-95 blade actually goes into the tube forming a better seal. They both seal the same way to the block. Not a big issue, but the 94-95 is a little better. I have pix of them side by side and there are no shape or size (length) differences. Soooooooo, if need be, Dan, you can use an 89-93 dipstick. I remember in another thread you mentioned the dipstick was one of the last items you needed to complete your rebuild. So if you cant find one, u can use the early one.
__________________
1993 SC 5.0L Auto Red, 1995 SC 5-speed Chameleon Blue 1992 Feature Mustang Convertible 5-speed Vibrant Red, 1991 BMW 850i 6-speed Brilliant Red (V12 )Sold: 89 SC stick Titanium, 90 35th stick, 92 Sport 5.0L stick, 94 SC stick Black, 1994 SC Auto Teal Totaled: 89 SC auto Twilight Blue www.mamn12.com for your mid-atlantic mn12 needs! |
#6
Quote:
Charles Last edited by 83GT460; 04-27-2006 at 11:09 PM.. |
#7
Charles...shut up already about your priceless dipstick tube
....ha...j/kHow is Wynn doing......are things coming along...project wise? ![]() |
#8
Ive been debating on using an early style Dipstick tube .. now I'm really confused
I have pieces of my 94 tube, it broke right below the flange .. I dont know if it can be repaired or if I should even bother. - Dan |
#9
Quote:
Charles |
#10
Quote:
__________________
#11
Kind of hard to tell from the pictures, the rusted one blends into your work bench.
But they do look very simular, with the exception of the finish .. and the way the bracket looks on the early model tube.When I pulled mine out, it looked like it had some silicone sealer around the base, which is probably one of the reasons it broke, I have the Ford shop manual, but I havent looked into it yet, I dont know if thats normal to do or if somebody had a problem with the engine before I got it. ... so, if the Early style is actually longer where it goes Into the block, it can be trimmed and bent to match the Late model tube ?? As long as it clears the windage tray everything should be fine is what I am thinking ? The bracket looks to be bent somewhat different, but it should still mount to the exhaust manifold stud the same way as the late model tube ?? And lastly, the late model Dipstick itself will seal into the Early model tube just as good as the late model ?? Sorry for all of the questions, I just want to be pretty specific with what I am doing here before I try to TIG weld and re-use my old tube, buy a new one and splice the two together, or just use an older style tube alltogether. - Dan |
#12
Maybe someone like FastEd can answer, I tried to search the Ford site with no prevail. I have a dipstick out of a 95SC and it matches the one you posted pics of for the early style. The base is much longer. I can add a pic if needed. I truly believe that all dipsticks are created equal for the designated years. Short base v.s. long for the 89/95 SC or base model dipsticks. It just needs to be verified. I have a call into a friend at a local Ford dealer to verify this. The only concern I see at this point is the windage tray and the amount of tube that protrudes into ther pan. The lengths of the tube aside from the base have been proven.
My only concern is trying to find an acceptable replacement for those of us that have been stuck with the Guiness Book of Discontinued parts. |
#13
I bought one from Capital Ford here in Raleigh a few years ago for my 91 SC. It was the only one he had.
#14
I checked with Ed already .. there are No SC Dipstick tubes in Canada or the USA, for any year, available through the dealership. Looks like a Junkyard item. Ive been trying to talk to Lokar about using a flexible braided style, but the Tech said they cant make a custom one with the bend in the part that goes into the oil pan, I dont see why not.
- Dan |
#15
Quote:
Charles |
| Thread Tools | |
| Pics Of Top Made By Wynn | CMac89 | Non Technical Forum | 22 | 02-28-2006 02:25 PM |
| Where is Wynn?! | Sampo | Non Technical Forum | 1 | 01-07-2006 02:25 PM |
| Wynn | Conan56 | Non Technical Forum | 2 | 10-14-2005 12:21 AM |
| where the heck is Wynn | mannysc | Non Technical Forum | 18 | 04-08-2005 12:40 AM |
| Anybody heard from Wynn Carter lately | Joisey Jim | Non Technical Forum | 31 | 03-01-2004 01:45 PM |
