Go Back   Super Coupe Club of America Forums > SCCoA Chapter Forums > Super Coupe Club of Ontario
User Name
Password
Register FAQ Members Garage Chat Search Today's Posts Mark Forums Read
Reply
Old 06-28-2006, 05:30 PM
tbirdsc357's Avatar
tbirdsc357 tbirdsc357 is offline
SC Newbie
SCCoA Member #: 2209
Rear Spring Air Bags....
Might give these a shot tonight.
I know a few have these installed in your cars, any tips/tricks to installing these?
Does the springs have to be removed or can I just stuff them in there?
Where/how did you run the air feed lines?
Also, how much air are you guys running?
Thanks.
Steve
Old 06-28-2006, 06:53 PM
HoseHead's Avatar
HoseHead HoseHead is online now
Asphalt Inhaler
SCCoA Member #: 2983
Steve,
I run bags @ 19-21 lbs on the rear of my '93. I'm also running Eibach Pro 1.5" kit on all corners. The bags give me up to about 2" of height adjustment from empty. I'm carrying about 160 lbs of audio gear so the bags are needed.
I didn't put them in so am not rehearsed with install procedure. Looking at them, I would suggest spring removal as the best way to ensure they don't get pinched and are correctly aligned. Others will have to advise for you.
The air lines exit each bag and the bottom centre and the hose is fed through a hole in the lower spring seat. The hoses are tyrapped in place, running to a tee and then up to the air valve located in the trunk. As you can see, a simple piece of bent stock riveted to the factory brace provides a nice secure professional fit for the valve. Easy access as well.
I did have two separate leaks this spring after car came from storage. These bags were installed several years ago, so all the lines need replacing. I'm going to use lines with a thicker wall than what was provided from the bag manufacturer.
Bruce
Click image for larger version
ID:	21119   Click image for larger version
ID:	21120   Click image for larger version
ID:	21121   Click image for larger version
Name:	Trunk Valve Brkt.JPG
ID:	21122   Click image for larger version
Name:	Trunk Valve.JPG
__________________
1993 Super Coupe - - - - - - - - - - - 1969 Lincoln Continental - - - - - - - - - - - 1990 Cougar XR7
Old 06-28-2006, 08:41 PM
SeanMatteson's Avatar
SeanMatteson SeanMatteson is offline
Anybody got a spare AR!!!
SCCoA Member #: 1716
Send a message via MSN to SeanMatteson
Quote:
I recommend that you run the lines separately into the trunk so that you can adjust pressure for each side individually. Some guys have had luck with reducing wheel hop by running more pressure in the one side.
I installed mine, but I did the springs at the same time so they were removed.
Cheers,
Sean
__________________
Sean Matteson
eMail me
{SOLD} 1990 Super Coupe 5-spd
Old 06-28-2006, 08:51 PM
HoseHead's Avatar
Asphalt Inhaler
Sean,
Understood and wise advice. I don't run this car very hard. But now that I'm retired, I'm going to build another SC for beating on.
__________________
  #5
Old 06-28-2006, 10:24 PM
tbirdsc357's Avatar
SC Newbie
Thanks guys.
I installed them tonight. Didn't need to remove the springs as there was enough room to get them in there. I ran my lines (two seperate) from the top of the springs and to the trunk, and inflated with 20 lbs
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
I found this FAQ on the SC Active non member Super Coupe Club of Western Canada 13 11-26-2009 05:19 AM
Continued ABS woes (and others) gregs90sc Super Coupe Club of Ontario 22 07-11-2007 08:35 AM
By Steve Campbell Cold air Intakes good article to read enjoy! victor malvar Technical Forum 0 02-04-2006 02:14 PM
rear spring rubbers ChrisPearl95 Non Technical Forum 3 03-07-2003 12:04 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©1996 - 2007, Super Coupe Club of America, Inc.
