Go Back   Super Coupe Club of America Forums > General SCCoA Forums > Non Technical Forum
User Name
Password
Reply
Old 10-19-2007, 12:13 AM
Darkside's Avatar
Darkside Darkside is offline
SC Newbie
SCCoA Member #: 2117
5-speed concerns
I feel that one of the biggest needs for our cars is an option for us 5-speed guys. I know that the syncros and other rebuild parts are getting harder and harder to find, so where are we going to be in 5 years? I am concerned about this issue, but yet, don't have any ideas on what to do. Every month my tranny gets a little more testy. The only solution I can think of is a C4, because I will not put an AOD in it. I would hate to give up the manual though. Anybody have any thoughts on this subject?
Old 10-19-2007, 12:16 AM
David Neibert's Avatar
David Neibert David Neibert is offline
Still loves the Cobra Rs
SCCoA Member #: 858
What's wrong with AODs ? I've got them in both my cars and they are about the only thing that never gives me problems. Buy a Lentech and your done.
__________________
91 SC AOD 4.2..2.3 Whipple........10.92 @ 126.70
93 SC AOD 347 Turbo.................10.04 @ 138.99
Old 10-19-2007, 12:29 AM
Darkside's Avatar
SC Newbie
Quote:
I fought with you over this when I got my first SC four years ago. LOL I don't like automatics. Manual valvebodies or not. I like clutches and shifting. Now, a C4 wouldn't make me happy by any means, but it is all I would settle for. Lightweight and cheap to get. I have two of them right now.
Old 10-19-2007, 12:57 AM
quick35th's Avatar
quick35th quick35th is offline
Autocross Terror
SCCoA Member #: 2313
Send a message via AIM to quick35th
Chris,
I am thinking T56 swap out of a GTO would do the trick. The shifter will pretty much come right out where the M5R2 does from what I have read.
Shane
  #5
Old 10-19-2007, 01:01 AM
Darkside's Avatar
SC Newbie
Quote:
Originally Posted by quick35th View Post
Chris,
Shane
Really? What about the bolt pattern on the bellhousing?
  #6
Old 10-19-2007, 09:03 AM
quick35th's Avatar
Autocross Terror
Quote:
Unlike our M5R2's the T56's belhousing unbolts from the transmission and there is a company that makes adapter belhousings that can be bolted to the GM T56 but have the SBF bolt pattern.
Shane
  #7
Old 10-19-2007, 09:18 AM
sinhumane sinhumane is offline
6+2=8
SCCoA Member #: 3304
that sounds intriguing.. but damn does it sound expensive!!!!!! a GTO? ZOMG $$!
  #8
Old 10-19-2007, 09:23 AM
SuperCharged91 SuperCharged91 is offline
SC Newbie
SCCoA Member #: 3365
Lol tyler do you get a post in on every thread that comes up
  #9
Old 10-19-2007, 10:44 AM
Jacob_Royer's Avatar
Jacob_Royer Jacob_Royer is offline
Its Alive!!!!!!!!!
SCCoA Member #: 3178
Speaking of the new GTO's i got a chance to ride in one of the 6.0 powered ones last week and all i can say is WOW!
__________________
93 SC Auto 111k
Fresh Motor
272 Comp Cam,ARP head studs
Ported and polished heads and intake,Ported late model blower, MP Inlet Plenum 10% od, 76mm Maf & TB , 42# Injectors, Full Exhaust
~96 Mustang GT 5speed 350k+
~99 Cobra 120k 312rwhp/320tq
  #10
Old 10-19-2007, 11:27 AM
NickM NickM is offline
Parts breakage tester
SCCoA Member #: 3297
I don't know about other parts (gears, sliders, shafts), but talk to Southern Gear on syncros.
See if they can get more of the carbon fiber lined blockers in like I and Mike Puckett got ahold of.
Nick
  #11
Old 10-19-2007, 11:36 AM
Darkside's Avatar
SC Newbie
Nick
I didn't know anybody was making carbon fiber-lined syncros. How did you guys get em. Did Southern have them special made for you?
  #12
Old 10-19-2007, 11:48 AM
CMac89's Avatar
CMac89 CMac89 is offline
SC Newbie
SCCoA Member #: 3429
Send a message via AIM to CMac89
You can get an upgraded T-5 from any aftermarket company like G-Force. They are all over the place and bolt right up. I think SpinningWheels-SC sells the shifter extension kit to make it work.
Unless you set a stick car up correctly, it isn't going to be as fast as a C4. Even so, you need the right converter, which will determine what your car will run. I will be putting a C4 in my car, sometime in the future.
I think a T-56 would be coolest for a stick tranny. You could run 4.30's with 30" tires, trap 125mph at 6K, and cruise 75mph at 2K (with basically any size tire.)
Come to think of it, I don't know if I wanna go to a C4.
T-56 VEY NIIIICCE!!
Click image for larger version
  #13
Old 10-19-2007, 12:48 PM
Mike Puckett's Avatar
Mike Puckett Mike Puckett is offline
SC Newbie
SCCoA Member #: 272
Southern Gear wouldn't tell me where they get the carbon fiber blockers from. I know they are carbon fiber because they are gray instead of brown and will conduct electricity. They don't always have them but they do get them from time to time because they know we need them. My concern is for replacement gears or the synchro cluster gears themselves. The F150 version has different synchro sliders than ours and they won't fit. I have 2 transmissions and keep one rebuilt and ready to swapout whenever I need it. You might want to try to buy another transmission just to have parts available.
__________________
90 5spd, best E.T. 12.250
best 1/4mi speed 112.89 mph
best dyno 388.42 rwhp 419.68 rwt
2004 Cadillac CTS, 14.616 @ 91.84mph.
  #14
Old 10-19-2007, 02:02 PM
Darkside's Avatar
SC Newbie
Quote:
What do the carbon fiber blockers cost, if you don't mind me asking.
  #15
Old 10-19-2007, 02:14 PM
SC Newbie
SCCoA Member #: 272
They were $200 for the set of 6. The reverse and 5th gear blockers were solid brass but 1-4 are fiber. I also talked with a Tremec rep and he recommended the TKO instead of the T56 but after discussing the project with them it was going to cost over $3000 to do the swapout and I decided not to pursue it. He also praised the M5R2 for its strength and frankly as long as the blockers are good I can speed shift it with ease. I know when it needs new blockers when I start missing 3rd gear repeatedly. I know what you mean about wanting to stick with the manual tranny. I'LL GIVE UP MY STICK SHIFT WHEN THEY PRY MY COLD DEAD FOOT OFF THE CLUTCH PEDAL.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Forcing Low Speed Cooling Fan On - Best Practice (or good enough) Mike8675309 Technical Forum 23 07-04-2008 12:49 AM
Speed Channel Has Cars At Carlisle On Tonight March 3rd!! lube70 Non Technical Forum 9 03-04-2005 11:48 PM
how to fight a traffic violation? mint93SC Non Technical Forum 20 03-05-2004 08:38 PM
