Go Back   Super Coupe Club of America Forums > Classifieds > Group Purchases / Specials
User Name
Password
Reply
Old 02-14-2008, 10:04 AM
XR7 Dave's Avatar
XR7 Dave XR7 Dave is offline
ask questions-get beat up
Wiseco Pistons group buy opportunity
This group buy was a great success and is now closed. Through this buy we were able to meet the volume requirements to obtain better pricing on the pistons on an ongoing bases. Please contact me if you need forged pistons for your SC motor.
Thanks,
__________________
Email me here.
Old 02-14-2008, 10:10 AM
joshbea6 joshbea6 is offline
Send a message via AIM to joshbea6
Dave,
If I can manage to get the $$ I want in.
Josh
Old 02-14-2008, 03:53 PM
nickleman60's Avatar
nickleman60 nickleman60 is offline
Quote:
Originally Posted by XR7 Dave View Post
Folks I'll be ordering some pistons this week and am looking to pass on some savings to anyone on the fence about ordering. Costs have gone way up over the past couple of years so don't go into shock about the pricing. This is the best I can do based on a volume purchase cost for custom pistons.
Features:
  • + .030"
  • Effective quench pads
  • Oversize valve reliefs
  • Extra thick crowns
  • Anti-detonation grooves
  • Lowered top piston ring
  • Lightweight slipper skirts
  • Additional machining on the undersides to reduce weight where it is not needed
  • Pressure balance groove
  • Dual pin oiling
  • Lightweight ring package
  • Stainless top ring with chrome nitride face
  • Lower tension oil rings
  • Offset pin location for quiet operation and reduced wear
  • Lightweight 2618 forgings with Wiseco's proprietary barrel design which allows for tighter clearances (as low as .004")
Options:
  • Any compression ratio you want
  • Any compression distance you want (custom rod lengths available)
  • Any pin diameter you need
  • Lightweight tool steel wrist pins ($100 additional)
  • Gold ceramic top and moly graphite skirt coating ($250 additional)
  • 6.200 H-beam connecting rods ($250 for off brand, $300 for SCAT)
Cost is $675 for the pistons, pins and rings. Production time is about 6 weeks. Please let me know this week to get in on this order.
count me in on the .030 pistons. don't know the difference between the stock length rod ( i thought was 5.926 )and a 6.200 rod, is it longer than stock or different because of the pistons? if i can use them count me in on a set of the scats also. I'm just assembling the parts for my friend who's doing the engine build for me. i can bolt anything to the outside of the engine but need someone else to do the internal stuff.
__________________
'94 SC AUTO - Twisted Blackbird
Last edited by nickleman60; 02-14-2008 at 07:23 PM.. Reason: added why i ask about rods
Old 02-14-2008, 07:23 PM
XR7 Dave's Avatar
Stock connecting rods are 5.915". The longer rods allow for a lighter piston. Keep in mind this will mean the crank will require re-balancing. If anyone needs this service I have an EXCELLENT V6 crank balancer available (not all shops know how to properly balance a split journal V6 crankshaft).
__________________
Email me here.
  #5
Old 02-14-2008, 09:07 PM
83GT460 83GT460 is offline
Count me in Dave, I will try and call you tomorrow to talk about exactly what I need and which options I want to go with.
Charles
  #6
Old 02-15-2008, 06:25 PM
skeem187 skeem187 is offline
I would like to get in on this too. I would like to talk to Dave about what options I should get for my application. Do you take paypal? 512 996 8836 just ask for Eric. Thanks
  #7
Old 02-18-2008, 02:56 PM
Flex's Avatar
Flex Flex is offline
Nickleman,
Aside from the lighter psitons, long rod motors keep the piston up in the flame front longer during combustion. This is supposed to improve hp and torque even more so. Also brings down the rpm's the engine will rev to.
Until recently, no one offered a stock lenght H-beam rod for our application. That is why 351 Windsor or 6.2 rods are used instead with custom pistons.
David, obviously I am in. Will get you the remaining details as soon as possible.
Anyone building a serious motor, jump on these. Will provide a solid foundation for any modifications.
  #8
Old 02-18-2008, 03:34 PM
cmill95 cmill95 is offline
[QUOTE=Flex;712849]Nickleman,
QUOTE]
correctomundo, it allows the piston to dwell longer at TDC and also improves the rod angle. adding a longer rod will make more power and add reliability(with appropriate tune ofcourse)
just make sure the wrist pin isn't into the oil ring, thing start to get a little dicey at that point
  #9
Old 02-18-2008, 03:45 PM
my friend who's building my engine explained the same thing you all did so i've decided to go with both the pistons and scat 6.200" rods, thanks alot for the answers. like i said earlier i can bolt anything to the outside of the motor but leave the internals to someone else...
__________________
  #10
Old 02-18-2008, 10:23 PM
Mike8675309's Avatar
Mike8675309 Mike8675309 is offline
Send a message via AIM to Mike8675309 Send a message via MSN to Mike8675309
I did some analysis of this in a thread where longer rods were discussed that might prove interesting.
http://www.sccoa.com/forums/showthre...iston+velocity
I highly recommend the H-beam rods, the weight of the stronger rods, and stronger pistons is significantly lower than stock assemblies. The longer rod allows for even more gain in decreased reciprocating weight. This should improve performance as RPM's increase in concert with improved heads, cam, and blower. If you are rebuilding your motor, I don't think you can go wrong with this combination.
I'll be curious to see if these are different than the earlier ones.
__________________
90 SC AOD
93 SC 5spd -441hp/462tq *SOLD*
  #11
Old 02-19-2008, 02:42 AM
CMac89's Avatar
CMac89 CMac89 is offline
Send a message via AIM to CMac89
**EDIT** forgot where I was posting.
Hook it up Double DEEEZZZ!!!!
  #12
Old 02-19-2008, 04:04 PM
XR7's Avatar
XR7 XR7 is offline
Thanks
Thanks for your efforts of getting us a group buy together Dave.
You can count me in on this... for a set of everything..
Karl
__________________
1989 XR7 Red 5spd
  #13
Old 02-21-2008, 12:18 PM
Flex's Avatar
David,
Did you get my last email ob the pistons. The cc on the chambers came in at 57 not 73 cc. Let me know that you got this.
  #14
Old 02-21-2008, 12:48 PM
Dave,
When do you need the $$$ by?
Josh
  #15
Old 02-21-2008, 01:11 PM
Flex's Avatar
Does anyone have Dave's number? He ordered my pistons based on a 73 cc chamber due to the unshrouding I did in the chambers but they actually cc'd at considerably smaller. He has not responded to emails and his pm box is full.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
2003 Cobra replica wheels from group buy Shockwave Non Technical Forum 30 03-09-2004 12:12 PM
Hey, Group buy on Magnum powers blower and inlets, cheap!!!! lube70 Non Technical Forum 28 11-14-2002 02:46 PM
SWB #003 found right here in my home! TBKHomeworld Super Coupe Club of Southern California 3 06-08-2002 12:39 AM
Updated: Group buy on 42lb injectors Wayne Ing Super Coupe Club of Ontario 4 02-22-2002 11:24 AM
GROUP BUY ON HEGO (O2) SENSORS! Bill A McNeil Super Coupe Club of Ontario 6 02-21-2002 11:31 PM
