FS: Built AODE / 4R70W
AODE / 4R70W Transmission - Level 2
This AODE transmission was built by Performance Automotive and Transmission Center. This Trans was street driven 2k miles in a 1995 302 Cobra, and was only taken out to make room for a 'glide. It uses an AODE case and the 4R70W gearset. It comes with a special pressure solenoid, which allows higher line pressure than the stock solenoid and a performance pressure regulator spring. This is the main cause of clutch failure in the AODE / 4R70W transmission. The roller clutch is removed and replaced with a heavy-duty mechanical diode with a Spiral "Plus" Ring Kit. This is the weak point on the 1992-1998 AODE / 4R70W transmissions and needs to be replaced for any high performance / heavy duty use. Two extra clutches are added to the direct clutch drum, which gives 33% more holding power (Alto Red Eagle Power Pack). This transmission has a Fairbanks high performance TransAction Kit and an oversize overdrive servo. The stock overdrive band is replaced with a carbon fiber band. This transmission takes care of all the weak points in the stock AODE / 4R70W transmissions. It's rated for motors up to 550 horsepower. Torque converter not included. Some info listed at: http://www.ford-aode.com/#Level%202 $750 OBO, it was $2k new. Plus shipping, or pickup in Albuquerque NM. Money order/cashiers check, or Paypal (add 3% to cover their fees) accepted. Don't be afraid to make an offer, but don't make me laugh too hard. ![]() Contact info is: MediumD@Gmail.com or (505) 363-4428, or PM. Last edited by MediumD; 05-26-2008 at 09:04 PM.. |
Oh yeah, it has a finned increased-capacity deep pan on it as well. Bump.
| Thread Tools | |
| 1990 SC Silver auto BUILT UP! | Odd is he | Cars for Sale | 6 | 12-09-2007 10:31 PM |
| Can a VSS be installed on a 99+ V6 Mustang 4R70W | Boss_232 | Technical Forum | 12 | 11-21-2007 03:58 AM |
| Custom Built Front Drag Coil Overs | 392Bird | New Products and Services | 160 | 10-03-2006 10:17 PM |
| Is there a "good" AODE for 2nd gen SC use? | Vernon | Technical Forum | 1 | 03-29-2003 06:36 PM |
