Jacob_Royer
SCCoA Member
Well after re-assembly it still ran like garbage so i took it apart again and discovered a couple lazy lifters so i replaced them hoping it would fix the issue.. it did not.. beginning to wonder if i have too much preload on the valves. 1.25 turns after zero lash per daves instructions but that seems to be excessive! I also did a compression test and am only seeing 120ish psi across the board on a new motor. Things have been stupid busy and I have not had the time or patience to mess with it lately. I hope to get back to it again soon after the holidays when things slow down at work.
