1989 SuperCoupe - 5 speed
DNA
1989 Super Coupe 5 speed
Oxford White exterior -- Burgundy cloth interior
Same owner since April 2004.
Southern California/Lake Tahoe area
Currently resting in Boise, Idaho
129,000 miles since car was rebuilt
Mileage was 113,500 in 2013
Custom engine with mostly stock parts.
Heads, plenum, intake ported/polished
BHJ harmonic balancer
Blower rebuilt in 2011
76mm MAF/75mm TB
New heads in 2011 with ARP studs
Bosch fuel pump
Custom M5R2 trans with brass blocking rings
New drivehaft
Shortened shifter
Aluminum flywheel 16lbs
Centerforce clutch assembly
Custom mandrel bent exhaust - no cats
Front suspension new in 2010 except struts
98 Mark VIII rear brake upgrade
New starter in 2015
Upgraded half shafts - The Driveshaft Shop (NC)
New rear hubs/bearings
18 x 9 Cobra replica wheels
Nitto NT555/G2 255-45ZR18 tires New ~500 miles
Windshield new in 2017 - CarLite factory solar tint
Kenwood 300 watt audio system matched components with custom subwoofer enclosure
to fit factory JBL location. Custom wire harness and RFI filters
145mph speedo upgrade from 94 SC cluster
Oil pressure gauge uses a real working sending unit
New VMM unit in 2013
Moonroof functional - water tight minor air leak
All new window exterior mouldings in 2017
Installed factory remote door for fuel filler
ABS pump rebuilt with new electric motor/accumulator in 2016
Battery is 2020 replacement
Front bumper cover replaced in 2017 due to parking lot mishap
Many more upgraded parts than listed here.
Just a highlighted recap list.
Most work was photo documented including transmission and suspension build.
Two very minor oil leaks at Left half shaft and transmission front seal.
A few small dings after 32 years.
Dashboard has sun damage and has matching cover
ARC no longer works. Just ended five year search for new struts/shocks
Tire shop tech hit LH fender with floor jack handle about five years ago.
Will post a better interior photo soon
Priced at $4000
rura
76mm MAF/75mm TB
Bosch fuel pump
New drivehaft
Shortened shifter
New starter in 2015
76mm MAF/75mm TB
Bosch fuel pump
New drivehaft
Shortened shifter
New starter in 2015
Priced at $4000
Where is this SC located?
Priced
DNA
I left a minute long voice message with more details at 10:30am this morning. Called a 2nd time around 2:00 pm. No answer and I did not leave a message....apparently you didn't keep the phone handy.
You stated you were available to call any time. I had expected to hear back from before 10:30 at night. These cars don't stay on the market very long. If you are in Las Vegas area, you realize Boise is 745 miles away on Interstate 15. I left that town last summer for this area.
DNA
The SC was sold today. It was a great 17 years of ownership and it was in its best form when the new owner drove it away to his home in the PNW.
See ya!
