Good afternoon
Did you check the following?
Battery voltage prior to start.
Check coil pack connector for security/corrosion.
Check for spark. See youtube scannerdanner attachment.
Engine harness ground on the back of the driver side cylinder head for corrosion or security.
Add fuel system cleaner.
Fuel pressure regulator/vacuum line. Check vacuum line for security, evidence of fuel leakage/smell.
Did you check fuel pressure holding pressure with gauge. Does it bleed off immediately?
Might have stuck open/close fuel injectors. This is a known issue when a car has not run for long periods of time. When you changed the spark plugs was there any evidence of fuel?
Check signal from EEC to accessible fuel injector connectors with a Noid test light (should be able to rent at a discount auto parts store) or remove the supercharger to get access to all injectors.
Do they pulse during start attempt? If so EEC is not the issue.
Here are some food for thought searches that might help.
What are the main causes a car would start, but not idle?
I just bought a car but I am finding a lot of details (car stereo, speedometer, etc.), But there is one that is affecting me the most. The car will start, it will go all the way to 1200-1500 rpm and will go down on the rev to 600 and it might oscillate up and down until the engine shutdown. I...
www.sccoa.com
Garage kept one owner 40,000 mile 89 Cougar XR7 running rough need guidance
Hello all. My name is Tony and I live in central Virginia just Southwest of Charlottesville. I am posting here because I can't find anything in central Virginia, and I grew up in York County, spent a good 30 years between the tidewater and peninsula. I inherited my grandparents cars this year...
www.sccoa.com
