Yes you can use a GM coupler from an M90 like on the GTP.How much is too much slop in a 94 blower? Do the spring couplers have some play or should they have none? Also can I just buy a gm coupler?
Appreciate it! I've read to use Anaerobic Gasket Maker to seal between the snout and the case when putting it back together, would that work?Yes you can use a GM coupler from an M90 like on the GTP.
