2014 SCCoA Top 15
neverfastenough
This is 2014 only, 1/4mi only. Ill post up an example format, and you can reply to this thread or PM in that format and Ill copy and paste if it falls in the top 15. Must be a ford mn12. Any power adder, any tire, any motor, dont care. Theres really no rules here, just a list to show the top 15 fastest guys of 2014(you driving your car!). I dont need pics of time slips, Ill take what Im told. If you see bs from someone, say it. You can comment and post in here also. Someone can sticky this if they want.
ET (to the thousandth) @ Trap (to the hundredth ) - Username - Vehicle
Example 1)16.125 @ 86.51 - XR7 Dave - 1990 SWB Tbird
^^^^If posting a time, reply to the thread in this format! and PM me a copy of the post!^^^^^
01.) 9.956 @ 135.12 - SCrazy - 1994 SC
02.)10.81x @ 126.20 - Landshark38 - 95 SC five speed
03.)11.144 @ 124.15 - David Neibert 1991 SC 4.2/2.3 whipple
04.)11.623 @ 115.98 - Kurt K - 1992 3.8L / 2.0 AR / AOD
05.)11.653 @ 117.96 - Trunk Monkey - 95 4.6L / Eaton M112 (SVO) / E85
06.)11.673 @ 115.59 - no164ford - 90sc MPXS auto
07.)11.879 @ 112.42 - cas23 - 90 tbird c4
08.)12.127 @ 113.30 - Racecougar - 90 Cougar XR7
09.)12.174 @ 109.87 - XR7 Phillip - 1990 Cougar 5spd MPX-S
10.)12.273 @ 111.xx - scnut80 - 1992 SC auto
11.)12.307 @ 113.31 - Chris Wise - 1990 35th Anniversary/ 4.2L / D1SC Procharger/ 4R70W
12.)12.332 @ 111.69 - Mike Puckett - 1990 5spd
13.)12.680 @ 107.62 - DrFishbone - 1989 Tbird 5-Speed/MPXs
14.)12.725 @ 101.35 - NASTY V6 - 1994 Auto
15.)
______________________________________________________________
2013 list located here.
http://www.sccoa.com/forums/showthread.php?128938-2013-SCCoA-Top-15&p=1022274#post1022274
For comparison, in 2013 we had.........
2 10 second cars
5 11 second cars
7 12 second cars
1 13 second car
4 of the cars were v8's
Mike Puckett
Well, let me start this year's off. Hopefully I'll improve on this time as the season goes on.
12.332 @ 111.69 Mike Puckett 1990 5spd
XR7 Phillip
First time out this season.
Also ran my best 60' ever. 1.565
Looking forward to a good year.
Phil
XR7 Phillip
Both the subframe bushings and rear diff mount are stock. I launched at 4900 rpm according to the datalog. I think it has a lot to do with the bushings. Absolutely no wheel hop.
no164ford
Good start for the year, hope to be out myself soon! That is a sweet 60' best I ever had was 1.59 and since 1.68ish. What tires are you running?
Phil
XR7 Phillip
Tires are M/T drag slicks. 26" tall and 8" wide on a 15" rim. Funny thing is that they are like ten years old... :rolleyes:
no164ford
It was a bad night at the track 3 runs destroyed 5 belts:( got something going on. I did get my best 1/8 mph +2 mph all 3 runs but never got a full run in:mad:
Best of the night 11.9901@111.83 1.8919 60'
3.8 v6 auto MPXS
BLOWN38
Nice run. Make sure the belt is short enough so that when it stretches it doesnt come in contact with itself at the tensioner.
no164ford
Good point I will check that when the new belts get here. I did find the lower belt Idler pulley was bent slightly so I changed it.
scnut80
I ran a (12.816 @ 106.36 - scnut80 - 1992 SC auto) back in may at Mason Dixon, not the best of the car, but the best this year so far in 80+ degree weather
cas23
My car did go 12.51 at 106 mph. sixty was like a 1.72 from idle.... I cant find my slips to post them..
cas23 - 90 tbird c4 12.51 @106 mph
