42lbs injector swap
SC1day
So I swapped my 90 SC to 42lbs injectors along with the sample tube. Now it runs a bit rough and fuel is coming out the exhaust. Is there something else I need to do?
DrFishbone
What color sample tube did you use? If I recall, the 89-93 SC's, using a C&L 76mm MAFS would need a purple-coded sample tube for 42# injectors. Also might want to verify your injector size....some of the all-black Lucas ones could get mixed up easily.
SC1day
So I did have the wrong injectors. Got the right ones in and it runs fine for a bit, but then runs like crap. I upgraded the fuel pump too. I got a code for an intake temp sensor. After I replaced it, gas started coming out the exhaust again. Any ideas?
